Awesome to hear. All the demos i’ve heard/watched seems right up my alley, and yeah - in some ways it does seem to trump my Virus. 25 voice polyphony is nuts. It sounds reaaaaally scifi which is just what I love. That’s what I needed to hear!
Great input. I think I’m going to finance one, I usually do with hardware… kind of a way of “renting” the hardware and try before you buy for $100 or so. For it’s price at 1k, it’s honestly a massive package. I think I spent $1500 on my Ti snow which is integrated.
I really like the idea of having dedicated hardware, I’ve only ever had an Electribe 2, so to be able to sit on my couch with some scotch and write patches and dabble away from the screen, is a big +1 for me.
It’s a very nice synth. The factory presets are, in my opinion, mostly weird and/or un-usable, - which turned me off using the synth in the beginnning. But as soon as I decided to get into making my own patches, the beauty of it began to show.
The menu diving is deep, but it works fine once you’ve spent the time needed to get to know it.
Look for the “init” (initialise) function, before starting a new patch.
For me, the one major downside of the Blofeld is its lack of a scale microtuning feature. You can use key track settings to adjust scale step size (to get 1/4 tone intervals, for example), but the steps of the scale will remain equidistant.
NB: Mark Pigott has a ton of inspired videos about patch-making on the Blofeld, and I can recommend checking out his Youtube channel:
The Blofeld and the Evolver are the two synths I owned in the past and wouldn’t mind buying again.
The Blofeld also does some great drums even more so if you have the samples al options installed and the Attack! Expansion
No, but at the same time, you are still in the very limited traditional on/off button matrix…
And you don’t need that much time to program and especially modulate your patches when you play MPE, you just PLAY you patches instead of finetuning all the LFOs and envelopes in your synth MATRIX.
Ok, I’m finished now with my weekly MPE propaganda ^^ .
It’s an expressive controller.
It’s the bridge between traditional EXPRESSIVE instruments and modern DIGITAL sound design. It opens up all possibilities in terms of expressive playing.
Consider this:
Without MPE, you need a second hand on a modwheel or any controller type-thing to bring in expressiveness in more than velocity or aftertouch. With MPE, you have pitchslide (x) AND timbre (y) on every single finger you play with? DO I have to write more?
Watching some stuff on the Kyra… whoa… this thing is nutty! Although a lot of people are actually using this in conjunction with the Blofield. Seems like quite the companion piece… 128 voices? Pretty gnarly.
Funny. I wrote and deleted a love letter to the TR8S in this thread a few days ago as Ive owned it about a year now.
It satisfies my groovebox/hardware only/jam video itch and is the perfect sketch pad/first draft machine for the music Im making.
I can’t lie that I do want a monosynth and some new DJ gear, but I think the only thing Im buying in the next six months is a sub for my PA.
In short the TR8S is perfect for my time/needs. I can sit down and get a the bones if a tune started at the kitchen table while watching bad tv and cooking dinner. So perfect.
