I didnāt read that as a normal thread, but actually having a player up top of the home page, like between the black bar and categories bit. Bonus points if it randomly selects a song from the LB (or a playlist curated from the LB or releases or whatever).
I personally think itās a great idea. It says āyou came about the music, hereās the musicā front and center - no clicking, no digging, do not pass go, just click play. I think youād be surprised by how many spins a track will get just by being thrust in peopleās faces like that.
Also, if weāre suggesting, I donāt know if you have the power to move categories around, but I really think the music related stuff should be up top (crowned by the LB), and all the rest of the chatter down below. Gives a newcomer the impression weāre actually focused on the music and not, you know, āthings that you piss on todayā.
The black and white header kinda clashes with the color of the forum itself, imo. Maybe try making the black part the same color as the background of nested quotes? Then changing the white to one of the muted browns.
when i click the reply button it doesnt quote the original and when i highlight and quote it only uses the username of the top post.
hmmm. i will get my head around this new format eventually
Cons:
Introduce yourself section? Is it not a thing anymore?
I havenāt figured out how to set a new avatar thing (thatās me tho it seems)
No signature block for everyone to remind me about their release, or whatever those were for!
Oh, also the āthis many new postsā thing is gone.
thats how i usually quote in the reply, but BFK managed to get quotes within quotes without having to do it manually though. fuck knows, not a big deal, i will just do it manually if i feel its necessary
i miss the signatures too. not sure if its possible on discourse.
an equivalent to the ānew postsā thing can be found on the home page at the top. there is ānewā and āunreadā. not entirely sure what the difference is atm, ive been using both.
yea i figured that out now. thanks. i knew it would be something stupidly obvious
edit:
i read what you said again and i think you were talking about something else. i wanted the multi-quote thing, but i think to get that you have to click the āquote whole postā button at the top of the box you type in
