edit: angry old man yells at cloud
A piece of audio equipment stoked my interest this morning on eBay that id never seen before, more info on Tuesday if i win it , that reminds me must set up the sniper
I love it when you’ve got a synth or whatever that you really get on with and you know the patch isn’t quite right, but if you just trust the synth and keep turning the knobs against the loop you’ve got going eventually you find that “aha” moment.
Hercules was the brand of the first controller I ever bought. DJ gear GAS is just as real as any other kind, be ware. It escalated to Pioneer CDJ/media players and my own PA lol.
Just fired her up to make sure she works, but won’t get time to give her a good listen/tweak until the weekend.
Why are you turning this against me?
He’s got fucking dogs, shame the dogs!
As a side note, I’ll post pics on Thursday.
Side side note:
Hey ya’ll. I don’t know if anyone here has any PA knowledge or not. I currently have two passive speakers and an appropriate amp. I’d like to add a powered sub. I’m a bit confused on the logistics of setting up this PA. I guess I’m confused on how to split the signal and get it to all three speakers properly. Is there anything special I need to know? Subs I’ve dealt with in the past have had an EQ knob to adjust where the cutoff of the sub’s frequencies are so you can pair it appropriately with the other speakers’ low end.
oh hey there. i do live sound.
a lot of powered subs have an inbuilt crossover, so you’d patch your source to the sub and the high passed output can be patched to your amp/tops.
if the sub you’re looking at does not have an inbuilt crossover you’ll want to add a crossover, dbx makes a reasonably priced one and several expensive ones as well. if the sub lacks a crossover, you’d need to patch your source to a crossover unit, and then send the high outs to your top boxes and then patch the low (usually mono) out to the sub. DM me on FB if you have questions. (:
I may contact you later on. Don’t need to sort this until July but was going to start shopping for subs now and related gear now. As always your input is appreciated!
Yeh but the one with the secret volcanoe lair and sharks with frikkin’ laser beams doesn’t.
rofl. Barely in charge of my own faculties. Anyway, I’ll stop straying from topic
The only iPad app I really keep coming back to is Grooverider G16. It has some handy preset sounds for my purposes. Is the easiest to use if feature sparse sequencer in App Land I’ve used. Very simple to load samples. And between the synthesis options and FX you can get your bread and butter sounds (kinda sorta).
iMini is also rocking my world right now. I don’t understand how that sound comes from an iPad…
edit: highly honorable mention to Ruismaker Troublemaker (303) because I just used it.
