Bongos aren’t that bad… the congas is where they get you.
https://www.akaipro.com/mpc-beats
This isn’t hardware, but it is almost exactly the software from the current MPC lineup last I checked. I downloaded this because it can be rewired into FL Studio as an instrument, which is really cool. I’ll be using that for sure, puts the FPC to shame. Anyways, its in the hardware megathread because in my dreams I’ll be able to program drums and midi inside of FL Studio, bounce that into the MPC Beats software, and then bounce that into my Force and thus my entire hardware setup, without having to run FL Studio and my hardware at the same time (which just sucks).
Hahahah here come the DAW’less jams videos. ![]()
:edit: I’ve been in the same boat tho w this mpc2500 so I REALLY can’t be too serious.
So…Digitakt users…how much do you really love your Digitakt…I’m leaning towards that being my next purchase in the fall…I don’t need it to be an all in one…I don’t need it complete whole songs w/o a DAW. I’d like to be able to start tracks on it and then do stripped down versions of finished tracks live.
I’m also keeping my Model:Samples because I love it and it doesn’t seem worth selling at the price point I’d likely get in return. So factor that in. I’m kind of imagining the M:S being used for percussion and the Digitakt for the rest.
don’t @me about synthesizers, I’m not a sound design guy, I’m a sampling guy. I’m good with mangling stuff from sample packs or rolling my own in my DAW and loading them on the Digi. Though I’m also pretty sure the Digi would handle single cycle wave forms well for doing some quick and dirty synthesis.
^Awesome!
What case did you get and what’s your goal with the system?
I’m in the process of reducing my case by half. Sold some stuff, bought some stuff, but with the same goal of it being a live case. Just half the size.
I went w the niftycase due to cost and inbuilt midi to CV/Gate converter.
My system is going to be a 4 voice sample playback system based around the Tip-top audio one unit. I’ll have 2 cv/audio mixers, and a source for random CV to get weird. The One unit can receive cv for sample select and can fire off 24/96 samples. That combined w a buffer repeater and I’ll have a crazy Autechre style percussion unit.
I’m going to combine it w my MPC2500 w the JJOS and some max for live CV tools.
That and I like a project, and I’m minimally employed ATM (thanks Covid) . ![]()
I love my Digitakt, and I was never into samplers before. There is a lot more filter and LFO options available on it, and 8 tracks of midi output is a fucking game changer, as you can sequence most other stuff from it
That’s good to hear. Already preferring to work with audio was hoping it would just reinforce that.
Wasnt sure this was worth making a new thread for. So I was looking at the Minilogue xd module as something use with my Minibrute 2 or maschine mikro’s built in keyboards. It seems from what I read the Minibrute 2 has better keys in general and desk space is a consideration. I’m thinking I can still use the Maschine software to host this and still use USB data cables? Does this sound like it should work? Not sure how popular of a setup that is,
I don’t know how the new Maschine works but I feel like you probably can’t connect the Maschine directly to the MB2 with USB? If both accept MIDI in and out via USB you can likely connect them through the Maschine software or through a DAW that you load Maschine into.
Sorry, I should’ve specified, I still have my Maschine Mikro mk2 from way before. The USB connections go to a USB hub that goes to the computer. I know that I use USB for Midi to and from the Minibrute2 and Maschine using the Maschine software. That seems to work okay so far, It’s adding the Minilogue XD Module to the mix I’m not sure on,
I’m wondering if I’m just overthinking it and I’m really just saying, hey I want to use this one synth or the Mikro to be the midi controller for this other synth through Maschine’s Software using USB cables. That seems like it would work fine, right?
If all three have MIDI i/o through USB it should work. You’ll just have to set each synth to a different MIDI channel. I don’t know the Maschine lingo but I had the original and used it to control multiple synths at the same time…I can’t imagine a newer version of the software wouldn’t do that. So each “pad” on maschine should be able to have a different MIDI channel. It should work. Edit: I’ve just not done it all over USB so that is the only factor I’m somewhat unsure of.
Maybe there is a Maschine specific forum or social media group you could pose the question to. The specific synths shouldn’t matter so much as can the Maschine software handle multiple synths all over USB?
I think the minilogue xd is a fantastic synth on its own. I’d suggest just getting it and making your setup work after. 4 voice, built in efx, analog and digital osc, sequencer. If I were in the market for a module to start a setup with I’d definitely be looking at that one. Wonderful device from what I’ve seen.
If you already have one synth sorted out being hosted by the software, then I think you’ll be fine just adding another on a new channel.
The only gotcha I’m aware of with usb midi is that you need to have a computer or a dedicated host port on the thing sending midi to your synths. But if you have that working with one synth already, then you have a midi usb host somewhere.
Speaking of minilogue, I think I just bought a Korg NTS-1
I ended up selling the takt, depsite it being a bomb, because it felt redundant next to the Force and I had some unexpected massive vet bills. But if I didn’t have the Force already the Takt would have the master of my studio, it’s great, flexible and just sounds good once you fiddle with the output compressor.
The Korg NTS was financed by some old guitar pedals I had lying around, it’s main goal will be effect processor for the MicroFreak.
The KORG NTS has my interest for sure.
It sounds soo big for such a tiny thing.
So, looking for something to jam about on that’s kind of instant, with a half decent sequencer that I can just keep going and overdub onto and live jam with my synths. With it’s last firmware update giving it quite an impressive list of functions like:
pattern sequence of up to 8 bars:
A new Sampler function allows for captured sound to be used as an additional sound source. These new sound sources can be edited with Filter, ADSR envelope, and LFO modulation.
WAV files from your own sound libraries can also be imported (via SD card) as new sound sources for the internal Oscillator.
And as it was on clearance, it’s going to cost me not much more than a Korg Volca Say a Volca and a half in money terms. Will pick it up on Wednesday.
