Thanks, everyone, for your responses. I’ve been looking into all the products that were mentioned.
One thing I’d like to add before replying: although I’ve been making music as a hobby for a long time, I still consider myself a complete newbie when it comes to mixing and mastering. It’s something I’m actively trying to improve, which is why I decided to get some studio monitors.
Based on the reviews I’ve read, what convinced me to choose the HS5 was the idea that if you can get a mix to sound good on them, it will sound good anywhere. This is something I’ve seen repeated in several reviews. I’m not sure how reliable that claim is, though.
I honestly didn’t know much about planar or open-back headphones, thank you, that’s really helpful information. I might consider getting something like that in the future. But right now I want some audio monitors. The main reason is that I want to hear the sound moving through the air, and also I’d like to be able to listen to my mix from different positions in the room also being able to sit somebody next to me and listen to it together. That said, I’ll definitely do some more research on planar headphones before making my final decision.
@Artificer @Manton Regarding the room, I don’t have a special room set up for making music. I live in a small apartment. I have a desk space in my living room where I have my studio set up. It is quite comfortable to work at, but there is not much I can do regarding treating it specifically for audio. Also, my setup is the same I use for work, meaning I have a PC with dual boot: Ubuntu for work and Windows for music. The desk is pretty big and the space I have between it and the wall on the other side (which is actually a bookshelf) is big, so my MIDI controller and my guitars fit in. But there is a lot of space continuous to it (where I have my sofa and TV). I do understand that all of this will definitely colour the sound.
Regarding @Manton questions:
- What is the cubic footage/meters of your room?
I don’t have anything to measure it with, but a rough guess; and this might be way, way off, is 6.5 x 3 m. This makes a rectangle, so this rectangle is actually divided into two parts (something like two squares): the living room (where I have a small sofa and my TV) and the work area (where I have the computer and all the gear).
- Where are you intending to place the monitors in your room?
The monitors will be on the desk in front of me, and there will be a wall about 10–20 cm behind them.
- You mentioned you’ve been saving - what’s your budget?
The budget question is tricky because right now I’m living in Buenos Aires (Argentina), and there are import restrictions here. So there is some gear that is not available, and the gear that is available is usually about 25 to 40% more expensive.
I will research the Kali Audio LP-6 V2 since they will be placed right next to a wall. They are available here and though they are a little more expensive they are within my budget range. Do you have experience with them? Appart from them being front ported what other advantages do you think they have?
