Tested some auto-betterizer and auto-anti-resonance plugins with a few tracks for two tasks:
- reducing problematic resonances that change fast on single tracks (judged by how much the result still hurts my ears)
- generally improving the sound of single tracks and the full mix (judged completely subjectively)
- options and flexibility (judged by how many different options there are and how helpful these seem to me)
It was just a quick and dirty thing, but I thought some people might be interested in the experiences:
GULLFOSS [multiple settings]
resonance reduction: 2
general sound improvement: 3
options: 1
notes: very subtle but nice sound improvements with soft settings
Hornet Thirty-One [Auto-EQ mode]
general sound improvement: 1
options: 1
notes: very inexpensive alternative to the other stuff but the Auto-EQ feature is very limited
DSM-V2 [multiple curves]
resonance reduction: 1
general sound improvement: 2
options: 2
notes: works not that great for resonance reduction imho but I like it more on groups and busses, even though because of the static curve, you have to know what kind of sound you are going for
Zynaptiq Intensity [multiple curves]
options: 2
notes: mostly strong but smooth and flattening compression especially in the mids and highs if not extreme different settings, kinda hit or miss with stronger settings, even though you can use custom curves
Oeksound Soothe 2 [multiple curves and settings]
resonance reduction: 3
options: 3
notes: it’s great for resonance reduction and ismilar tasks, the sharpness parameter and other options are great
TBProAudio DSEQ [multiple curves]
options: 3
notes: similar to but not as good and less sharp as soothe. Also had problems with lagging and visual feedback dropping out but might be related to the demo (soothe demo was working fine without lags)
Trackspacer [NOT USED AS INTENDED but instead sidechaining it to the same track to suppress resonances following a suggestion]
general sound improvement: 0
options: 1
notes: works at least a bit for soft resonance reduction, not perfect but sounds good with around 5-15%, especially when narrowing the frequencies affected
End result (reminder: I’m only testing “resonance reduction” & “general sound improvement” here):
Oeksound Soothe 2 [multiple curves and settings]: 8
TBProAudio DSEQ [multiple curves and settings]: 6
GULLFOSS [multiple settings]: 6
DSM-V2 [multiple curves]: 5
Zynaptiq Intensity [multiple curves]: 5
Hornet Thirty-One [Auto-EQ mode]: 4
Trackspacer [sidechained to the same track]: 3
Since I’m a big fan of Zynaptiq Adaptiverb and Morph, I kinda expected Intensity (and also DSM-V2) to be a good competitor in terms of general sound, but I liked what Gullfoss and Soothe did to my projects.
Trackspacer is normally intended for frequency-specific sidechaining, but works not that bad for resonance reduction. DSEQ is pretty good and not far behind soothe imho.
