hey troops, i remember there used to be a deticated thread for finding specific sounds, idk if its gone or im being a fool and cant find it.
anyway im looking to get a sound similar to the rising and falling synth that starts creeping in at around 4:07 and plays throughout the rest of the track.
heres the track (one of my favourite pendulum tracks btw, why does no one talk about it?):
Part of it I would guess is modulating the pitch/frequency of the FM modulator that is applied to a normal oscillator…either by an xy controller or by key modulation which adjusts the pitch envelope by a specific value depending upon the note that’s played which is possible in fm8
I think this is the thread you were talking about btw
I agree.
1000% UVI Falcon & or Omnisphere.
I might be wrong as it could be any plugin actually.
But the sound of Falcon is quite noticeable to my ears, the highs sounds like Massive X as well.
As the album was released early 2008, and Omnisphere only came out that same year. It probably isn’t Omnisphere. It sounds like a variation of a hoover. Lots of tut’s out there for massive for that. I’d start there and play around with the portamento and filters to give it a less aggressive sound.
