Bitcrushing, downgrading the quality of the sound especially when you bring out the higher harmonics…mixing the dry with the processed for extra umph…also with resampling…
It opens up possibilities…not only for sound design.
I’ve always loved bitcrushers; lately I’ve been using a lot of Unfiltered Audio’s Dent Crusher but I also like their regular VST versions outside of that. Something about DC’s specific algorithms just works awesome every time, and they even have a faux circuit-bent crusher type of thing on it similar to the version on regular Dent.
Even regular downsampling can be a nice effect / unintentional shaper, even if they’re technically the same thing
The Akai Force has built-in the Air Plug-in lo-fi. It’s really really good, from adding a bit of highs to totally destroying shit up.
And it’s got envelope and Lfo.
And if you’re fancy you can use the envelope follower to control various parameters…
