Tried doing another tutorial but obs is literally capturing the sound of my air-conditioner which means it’s using my laptop mic…instead of recording the output of my soundcard…
How do I fix this…
How do I fix this…
I think I have an older version, but I see a “Mixer” panel at the bottom of the window in the middle. There are the different channels including desktop and mics and the levels can be adjusted.
If that doesn’t help, check -> File -> Settings -> Audio and select the correct audio source somewhere.
