Hi
Saw this on KVR and thought Id post it here as very interesting, useful and hopefully helpful.
https://www.kvraudio.com/forum/viewtopic.php?p=7624448#p7624448
To uninstall the current driver always use DDU and
set it to reboot in safe mode to remove the driver.
https://www.wagnardsoft.com/
Updating nVidia drivers: Standard vs DCH drivers (I prefer the standard)
https://support.newtek.com/hc/en-us/articles/360041324933-Updating-nVidia-drivers-Standard-vs-DCH-drivers
[color=#008040][size=200]NVIDIA Tweaks[/size][/color]
The Basic workflow is:
- Disable Windows 10 Hibernate
- Disable HPET
- Use NVSlimmer to create a less bloated NVidia DRIVER
- Use DDU to uninstall the current driver
- Install the less bloated DRIVE trimmed by NVSlimmer
- Adjust BOTH NVIDIA and Windows power settings
- Make sure NVidia driver is using MSI
The [color=#8000BF]main [/color]NVIDIA FIX :tu:
https://nvidia.custhelp.com/app/answers/detail/a_id/3130/~/setting-power-management-mode-from-adaptive-to-maximum-performance
[color=#BF0000]MSI[/color](Message Signaled-Based Interrupts) utility V3
https://forums.guru3d.com/threads/windows-line-based-vs-message-signaled-based-interrupts-msi-tool.378044/page-71#post-5826955
Here MSI for the Realtek audio and NVIDIA GPU was not enabled, the Realtek LAN
was with set to HIGH priority. :o
Here it is not a server, it is now set to LOW :!:
I suspect for your DAW machines you may want to enable MSI for the GPU and
set it to LOW priority.
NVSlimmer, good to create a debloated installation driver
https://forums.guru3d.com/threads/nvslimmer-nvidia-driver-slimming-utility.423072/
[color=#BF0000][size=200]AMD GPU Tweaks[/size][/color]
Stuff you may want to disable
Or just install the driver
https://youtu.be/IhBLqTVxcBM
For AMD GPU 5500/5600/5700 series, do not disable.
At least not with the current drivers…
[size=150][color=#8000FF]Some Windows 10 tweaks[/color][/size]
Set Windows Power Plan to “[color=#800000]Ultimate[/color]”.
(For AMD CPU it is different, more at AMD part bellow)
https://www.tenforums.com/tutorials/107613-add-remove-ultimate-performance-power-plan-windows-10-a.html :tu:
https://www.tenforums.com/tutorials/2859-enable-disable-hibernate-windows-10-a.html
Some good stuff:
[color=#BF0000][size=150]Tweaks for CPU AMD Ryzen 3000+[/size][/color]
Use latest Windows 10, not OLD builds…
[COLOR=“Red”]Disable HPET[/COLOR]
https://silicophilic.com/disabling-hpet-settings/
From Search, enter cmd and select Open as administrator.
Type the following commands to disable HPET
[COLOR=rgb(44, 130, 201)]bcdedit /deletevalue useplatformclock
bcdedit /set disabledynamictick yes[/COLOR]
Restart the PC for the changes to take place.
[color=#800000]After [/color]installing AMD Chipset Drivers
https://www.amd.com/en/support/chipsets/amd-socket-am4/x570
In the motherboard BIOS:
- Spread Spectrum Control = [COLOR=“Red”]Disabled[/COLOR]
[color=#8000BF]- PCIe = GEN3 (less bugs and more silent chipset fan)[/color] - Global C-state Control = Enabled
- Power Supply Idle Control = Low Current Idle(if you have a new power supply unit)
- CPPC = Enabled
- CPPC Preferred Cores = Enabled
- AMD Cool’n’Quiet = Enabled
- PPC Adjustment = PState 0
- ErP = Disabled
- PBO = Disabled (initially I keep it disabled)
https://www.reddit.com/r/Amd/comments/dtffnt/in_light_of_1usmuss_power_plan_and_his_suggestion/
Now play with the machine and if all is OK can set the CPU CLOCK RATIO
to a fixed value to keep it locked at higher speed, lest say the
BLK = 100MHz with CPU CLOCK RATIO = 42 will get 4200MHz in all CPU cores.
Attention, [COLOR=“red”]max temperature[/COLOR] for the CPU is [COLOR=“red”]75° Celsius[/COLOR] or [COLOR=“red”]167 °Fahrenheit[/COLOR], NOT MORE! :-o
BTW, new DRAM Calculator for Ryzen v1.7.3 ![]()
https://www.guru3d.com/files-details/download-ryzen-dram-calculator.html
AMD Ryzen - RAM OC Community
https://www.computerbase.de/forum/threads/amd-ryzen-ram-oc-community.1829356/
