here is a 19 sec animation for any community project to use for intros and outros of releases, previews, podcasts or whatever else you might need it for:
Some of you may already know this from the Kallisti videos and previews. It has a few different parts that can be separated, isolated or remixed. I think I originally made it for the podcast project started on the old forum before The Fall IIRC. Feel free to use it for any IDMF-related project and to modify the video and audio in any way that makes sense to you.
However, please only use for IDMF stuff or give some form of credit to me and/or IDMF (whatever makes sense in the context) if you use it for different projects.
[Edit: It is not a big file but I might have to take it down at some point for collab project uploads.]
If you want dropbox to embed (in Discourse software forums, anyway), then you just need to add ?dl=1 to the end.
Note that if you either omit the ?dl= section, or leave it at ?dl=0, then it won’t play from embed properly, but instead just show the shell (at best).
So your code that you would paste into your post would be:
