I asked chat gpt how to go about a track
So I asked chat gpt to generate a breakcore track in emaj 178bpm… drum patterns switch from 8/7 to a 9 against 5 polyrhythm in 13/8 time… modded rhodes piano as a lead, violins as a secondary melody with pads….and a glitchy Reese bass wub in 4/4 time signature. With each bar for the drums varying in sequence.
It said:
Cant generate an actual audio file, but I *can* fully compose the structure, notation, drum programming logic, melody lines, polyrhythms, arrangement map, sound-design notes, and a pseudo-MIDI score that you or a producer can implement in a DAW.
Below is a complete **4-minute breakcore track blueprint** that follows every constraint you listed.
# :headphone: **Breakcore Track Blueprint (4:00)**
**BPM:** 178
**Key:** E major
**Primary elements:** Amen break (heavily chopped), glitch‐Reese bass in 4/4, Rhodes lead, reverberated violin, ambient pads.
**Special rhythmic constraints:**
* **Intro section:** Drums in **8/7** time using Amen break variations
* **Main section:** Polyrhythm **9-over-5** inside a **13/8** meter
* **Reese bass stays in 4/4** the entire track
* Drum sequence changes *every bar*
# :white_check_mark: **FULL SONG STRUCTURE (4:00)**
## **0:00–0:24 — INTRO AMBIENCE (no drums yet)**
**Time signature: 4/4 (no rhythm conflict yet)**
* Warm E-major pad swells
* Filtered noise glitches + vinyl texture
* Reese bass pulses quietly on beat 1 of each bar (sidechain ducking pad)
* Rhodes introduces broken chord fragments:
* Emaj7 → C#min9 → G#min11 → F#add6
* Violin holds slow, airy harmonics (high E, B)
## **0:24–1:32 — SECTION A — BREAKCORE IN 8/7 (Amen break variations)**
**Time signature: 8/7**
**Amen break chopped into 7 subdivisions per bar**
Every bar’s drum sequence changes—examples provided.
**Drum pattern logic examples (pseudo-notation):**
### **Bar 1 (8/7)**
K – S - K S - HHH
(ghost snare flams between beats 4–5)
### **Bar 2: reverse chop + timestretched slices**
rev-HH K Sg Sg K HH glitch stutter
### **Bar 3: granular roll fill**
K K SSSSSS (32nd snare roll) HH K
### **Bar 4: silence on subdivision 6 → hard kick on 7**
K S H H - K !!!
**Melodic content continues:**
* Rhodes plays main motif (theme A):
E4 – G#4 – B4 – D#5 – C#5 – B4 – G#4 (syncopated)
* Violin responds with airy, reverb-washed melodic tails.
* Reese bass stays in **4/4**, meaning its downbeat “wub” lands in different positions relative to the drums each measure → intentionally disorienting polyrhythmic effect.
## **1:32–2:20 — TRANSITION TO POLYRHYTHM (build section)**
**Time signature modulates from 8/7 → 13/8**
* Drums fade into glitch fragments
* Rhodes switches to arpeggio pattern based on Emaj9
* Violin now uses shimmer-verb swells
* Pads widen stereo image with slow phasing
* Reese bass now becomes louder, still hitting only beat 1 of each 4/4 bar
## **2:20–3:32 — SECTION B — POLYRHYTHMIC 9:5 OVER 13/8**
**Time signature: 13/8**
**Drums play a 9-beat cycle while another layer plays a 5-beat cycle**
→ Together they complete their full overlap every 45 subdivisions.
**And each bar the rhythms still change.**
### **Drum Layer 1 — 9-cycle (fast, chaotic):**
K - S S - K H H S (9 units)
### **Drum Layer 2 — 5-cycle (slower, hard kicks):**
K – S – K (5 units)
### Example 13/8 bar alignment (conceptual):
|1 2 3 4 5 6 7 8 9 10 11 12 13|
L1: K - S S - K H H S - - - -
L2: K ---- S -------- K -----
**Melodic/Rhythmic elements:**
* Rhodes plays Theme B (more angular, breakcore-ish):
E5 – D#5 – C#5 – G#4 – B4 – F#4 – E4 – C#5 (fast runs, syncopated)
* Violin complements with long harmonics that fall across bar lines
* Pads thicken, adding tension (Emaj13 + suspended clusters)
* Reese bass (4/4) now aggressively wubs on each beat → superimposed over 13/8 → intentional rhythmic “grid-tearing”
## **3:32–4:00 — OUTRO (ambient collapse)**
* Drums stop abruptly
* Pads fade down
* Rhodes plays slow descending motif
* Violin performs final glissando up 2 octaves
* Reese bass gives one final low-passed wub with heavy reverb
Fade out.
# :musical_keyboard: **MELODIC MATERIAL SUMMARY**
### **Main Key:** E major
**Chord vocabulary:**
* Emaj7, Emaj9, Emaj13
* C#min9
* G#min11
* F#add6
* Amaj7 (borrowed for color)
### **Rhodes sound design:**
* Bell-ish tine attack
* Slight overdrive
* Stereo chorus 20–30%
* Short plate reverb
* Keytracking low-pass filter for dynamics
### **Violin sound:**
* Highly reverberated
* HPF around 250 Hz
* Occasional shimmer reverb
* Long sustains + gentle vibrato
### **Ambient pads:**
* Wide, slow LFO movement
* Gentle phaser
* Built from layered saws and formant-filtered noise
# :speaker_high_volume: **BASS DESIGN (Reese “wub”)**
* Consistent meter: **4/4 only**
* Wubs hit beat 1 every time
* Distortion + notch-filter modulation
* Heavy sidechain from Amen break
* Acts as an anchor amid chaotic time signatures
# :drum: **DRUMS — Amen Break Chops**
* Slice length frequently warped
* Glitch cuts (1–4 ms granular)
* Reverse hits
* Ring-mod bursts
* Vinyl crackle layer
* Every bar = new variation (true breakcore ethos)
# :page_facing_up: **OPTIONAL: PSEUDO-MIDI / DAW GRID EXPORT**
If you’d like, I can generate:
:white_check_mark: MIDI for each section
:white_check_mark: Machine-readable note values (ticks, PPQ, subdivisions)
:white_check_mark: Drum-trigger patterns
:white_check_mark: Sound-design presets (Serum, Vital, Operator, Massive X)
:white_check_mark: A full score in text-based notation
Just tell me what format you want (MIDI-style text, tracker notation, DAW grid, PDF-like score etc.).
If you’d like, I can also **name the track**, write **cover art**, or create an **arrangement PDF**.
i read 8/7 time and kinda stopped reading
Lmao. Well, here’s my 2-hour prototype inspired by the first section (the chords didn’t sound like shit, surprisingly). Reminds me of people following guides from chatGPT on building houses in minecraft. There’s just enough there to almost work, but without a human to help the ideas along, it falls apart. It’s not the amen break, but close enough for demonstration
https://soundcloud.com/aftermath81/aiidea1/s-IZOVYvseVvH?si=1120fe068d8d4dafbb01bcaaa8260b03&utm_source=clipboard&utm_medium=text&utm_campaign=social_sharing
(also ignore the fact that it isn’t in 178bpm, i forgor)
I think i broke it
Yeah this is pretty much the truth.
That’s the whole thing is though, teaching them how to do shit.
The bright side is that with AI…
It will go scorched earth and take a flamethrower to all the cheesey formulaic commercial pop music that is dominating this art medium. It will get rid of the formulaic commercial music from the industry.
Mixing and mastering will get better.
It’ll be another thing that can help us make the music that exists in our imagination..
It will raise the bar.
So yeah.
As far as making a living as a musician I cannot even fathom the impact it will have.
I agree with you man. why it’s important to teach it not to suck. well, not important to those who don’t care or are rejecting it outright, but i hate when music sucks. it won’t get better if it doesn’t get trained. then music will just suck even more, forever.
