I’m testing this Dark Energy (MKI) and can’t tune it properly. The scale is off, it distributes one octave range from the oscillator in about two octaves and two halfsteps in the keyboard, making it impossible to play properly tuned sounds, as it outputs microtones.
I can’t find any solutions, the only thing stated in the manual is that the octave is 1CV, and the built-in MIDI-CV converter takes care of everything. I tried plugin different keyboards but everyone gives the same result.
I tried runing MIDI from a Korg Poly 800 and a Nord Stage 2 to my interface, through Ableton then into the Dark Energy with DIN cable. Also tried runig directly from the keyboards to the DE. Also noted that the reference note, the lowest C, stays tuned, but other notes keep tuning down. I made sure any LFO is messing with the VCO. So I don’t know if it’s a problem with the oscilator, with the converter, or what.
Any help appreciated.
