this is just a tester thread for the wiki idea.
post if you like, but this will be removed eventually.
jk, this is the HOLY jesus BIBLE of compression secrets
if anybody wants to make edits to one of these and let me know how it works that would be great. you should only be able to edit it at trust level 3 or higher, but if im wrong please let me know
test:
blah blah compression is like a tiny dancer who rides your fader really really fast blah blah
…increase or decrease dynamic range blah blah. Not to be confused with file compression, where it mainly sucks.
(not an actual compressor pictured, that is a dildo on wheels)
tags:
compression compressor expander #expansion#dynamics
multiband together and endeavor #relatable#fakenews
controls the perceived volume output of the sound and adjusts the db levels accordingly to a users desire, can be used to control the dynamic range when applied to individually to each element, or to balance everything out when applied overall during mastering stage…
comedic relief…
How come the sine wave didn’t see the compressor coming?Because it had a quick attack!
i disappear for a couple of days and my wiki goes mental
@bfk
thanks for the info. i will figure out what needs to happen to secure it to trusted users.
@relic
exactly that. it would work great for community built resources. people with high enough trust level (i will get back on how to set that) would be able to edit entries in the ‘dictionary category’ (whatever that might be called). hopefully it would be built on over time to create a comprehensive directory of definitions.
wiki posts could still be created in other categories, which would work the same way, but the idea of a section for wiki information is what is attracting me.
its possible that wikis can be disabled outside of certain categories, but i doubt its worth doing.
Sorry I dropped the ball on this. Ive seen the setting recently. I think anyone who is level 1 trust level ahould be able to edit but not create a wiki.
let me know what you need, if you want me to change something or if a few people need permissions changed on their accounts to go forward with the wiki project
i dropped the ball too XD
hopefully i will get my ass back in to gear on this and get the idea running again. i think im going to need to re-learn how it works
