Recently i’ve got my first physical synth (Behringer Phara-o mini) and also ordered korg volca drum. I love physical equipment cus its way better and comfortable to work with it. But for live-music i need sampler to make more various sounds, soon i’ll also get mixer. So topic is about samplers, like should i buy cheap but with limited capabilities korg volca sample 2 or bit more expensive Roland AIRA compact P-6? Also will be glad to hear what samplers/grooveboxes do y’all using.
I’m taking supplements to grow a third kidney so i can trade it for one of them 40th anniversary Rossum SP1200s
Search this thread - you should find all the info you need and the GAS you don’t need:
It’s really up to you and your price range. The elektron model samples is a pretty good machine with added tweakability. MPC samplers like the Akai MPC sample are good fun and decent production machines. Any sampler needs good “samples”
Regardless of what hardware you use, it’s about finding, creating or programming the sounds you want to sample.
If you own an ipad you could start with the Koala app. It’s quite capable and can be midi synced. Learn about sampling, get comfortable with the features then move to a hardware sampler. Just a quick way to get started.
