Hello Everyone,
Good to be back on the new forum, nice one for setting that up again. You know who you are!
Anyways, I’ve been in a rut of late because the rooms I’ve had my studio set up in have not been treated. The rooms have also been square and horrid with standing waves a plenty. This has meant my monitoring has been so badly tainted that everything I’ve been producing is crap. From sound design session, all the way to finished produce. This has meant a lot of back and forth with my mastering engineer and has caused so much frustration.
That was the problem, now I’ll present the solution and it’s called Sonarworks. I purchased a pair of Shure 1840 Open back headphones which were individually calibrated. My mixes have been perfect ever since using the calibration and software. It basically puts a filter on the master output to correct the errors the physical headphones create so I’m hearing a completely flat response.
If you have these types of problems where your mixes are not translating. Look up this company. It’s amazing!
