The layout definitely looks more upfront and accessible. Probably isn’t though. I do like the look of it though.
Softsynths & FX Thread
Picked these up today and they designed them with “inbuilt tutorials” pretty much giving an idea as to what it will bring out, Kinda neat because I just assumed all compressors served the same function…Show’s what I know.
Those Arturia compressors look great especially for the price, somebody was saying they work out at £20 each, from what I’ve read over at slutz their as good if not better than anything outhere
A far cry from the days I payed £400 for the tubetech compressor plugin on the powercore platform
yeah 99 jibs is not a bad intro price. Arturia tends to be expensive but they are really good about throwing out unbeatable deals for introductory software. Fuck I think Pigments was 69 around black friday and I got the V collection 6 for 149 or 199 I believe it was? Either way it was the only way I was gonna get it.
I only use Sylent1, Nexus and Absynth 3. But there is a very popular synth called “Serum”. You might want to check it out. If you can afford a rompler go for Omnisphere. They have Serum as a rent-to-Pay option. Where you pay $9.99 for 19 months and it is yours after that.
Massive X just looks like another Reaktor module.
Is it just another Reaktor module? I’m really sick of NI just making more Reaktor stuff instead of genuinely new synths. There’s some Reaktor gems but most of the stuff they publish is CPU-hog mediocre shite.
Reaktor 6.3 update wasn’t showing up in my native access, after a bit of searching about I found Reaktor now only supports Mac 10.12 or higher, gutted
I’ve got a feeling Massive X probably won’t be supported on my machine.
So why don’t you upgrade your OS you ask?, well Apple no longer support the cheese grater style Mac Pro since 10.11, and it still has so much power/performance that it would be a disgrace to have to buy a new machine.
I’m pretty sure they’re just focused on that GUI type.
Everything has to look super polished so you’ll shell out the cash. Modern sleek. I don’t think I’d buy it though. I don’t even use the Massive I have now.
yeah i have K-12 from k8.never used massive.i used predator and predator2
basically my go to.but i am looking forward to massive x,ya never know,could be super cool or a polished turd.
I’ve got a cheese grater coming, I’ll stick w software versions I have for it.
Soon I’ll put a UAD card in it and just stick w 10.11.
This reminds me so much of the FL Studio native plugin Sytrus, especially with the peg matrix in the center. It’s just as fucking cool as it looks.
as you’ll probably know theres ways of patching so you can upgrade to the latest OS but by doing this it stops your wireless card working, then its a mine field trying to get the correct upgrade wireless card and then fitting it looks rather messy and thats coming from somebody who regularly built euro modules.
Oh and if you haven’t already bought a UAD then don’t, theres native plugs out theres on par and better.
I want the DSP acceleration for mixing larger projects. I’ve been hitting a wall w my MBP, perhaps I’ll run the grater through its paces once I get my hands on it before jumping into the UAD.
I thought we had an iOS thread, but as I can’t find it I’ll post here.
Sugar Bytes Factory is free and it sounds really good, similar to Razor in some ways
