Best way to sustain echo/delay - Page 2
Old 17-01-2017, 02:36 AM   #21
AnmolJ
AnmolJ will become famous soon enough
Re: Best way to sustain echo/delay
Automate the feedback knob.
AnmolJ is offline   Thanks Reply With Quote
Thanks to AnmolJ
Parricide (23-01-2017)
Old 23-01-2017, 09:04 PM   #22
Parricide
sloppy cunt
Parricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MC
Parricide's Avatar
MC Status: 18032619
i cant believe i have never tried that myself i imagine you can get some interesting results like that. it will take some time to get just right so it doesnt die out or loose control but it sounds fun.
im going to play with this concept later, thanks for the tip.
EDIT:
just had a little play with the idea using a simple delay with filters on the feedback path, no frills, and i got some nice sounds. i was able to throw the "upcoming" sound subtly into the feedback path and bring it in more and more as the sound progressed. i didnt get a chance to blend that properly with the second sound yet because i just wanted to play quickly, but it will be easily achievable when combined with other tricks and some layering and mixing.
signature loading...
Parricide is offline   Thanks Reply With Quote
Old 24-01-2017, 04:59 PM   #23
FairyLand INC.
Microknight
FairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud ofFairyLand INC. has much to be proud of
MC Status: 1160
Originally Posted by thanatos View Post
compression and soft clipping can shape delay
This.... basically set up a compressor to smash the shit of your delay line by placing it after the delay.... automate the threshold and the makeup gain just before the last note of your phrase - this will bring up the tail of the delay..... also works amazingly on reverb, you get a thick tail without washing the sound out.... compressing the master reverb, the room the tune is built in, works wonders as well, again allowing you to use less decay on your reverb tail, giving a big sound without washing out the sound....
FairyLand INC. is offline   Thanks Reply With Quote
Old 29-01-2017, 03:41 AM   #24
EggplantPurple
EggplantPurple is a splendid one to beholdEggplantPurple is a splendid one to beholdEggplantPurple is a splendid one to beholdEggplantPurple is a splendid one to beholdEggplantPurple is a splendid one to beholdEggplantPurple is a splendid one to beholdEggplantPurple is a splendid one to behold
Toronto/Tkaronto
MC Status: 860
Everything's been said. If you want some free VST suggestions for looping I've used AngstroLooper, Freezechamber, and ElotTronix. Wok Echo Freeze Chamber is another awesome plugin but not sure if it's still available. For free big delays I like Rubbadub, Tal Dub, and arcDev Dub Box.
EggplantPurple is offline   Thanks Reply With Quote
Sounds from VSTs do not follow full envelope (doesn't release after "sustain") samk44 Sound Design, Mixing, & Studio Techniques 12 15-05-2016 02:50 PM
Logic 9 - Random Sustain & Missing Notes on MIDI Out? Opus Science Workstation Center 1 11-04-2014 11:33 PM
[House/Deep house?] Sradc - Sustain sradc Listening Booth 3 21-11-2013 08:35 PM
[Altmodisch Sustain Piano] SCANDINAVIA Søvntrang Listening Booth 10 29-06-2012 01:17 PM
