Tutorial: Ableton live (7) - no mouse/keyboard navigation + performance. - Page 2
Old 25-04-2008, 07:59 AM   #21
geist
geist is currently spamming hard
Re: Tutorial: Ableton live - no mouse/keyboard navigation + performance.
this is helpful, thanks. I've been wanting to get deeper into live for a while now
geist is offline   Thanks Reply With Quote
Old 03-05-2008, 04:12 AM   #22
gbsr
gbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MCgbsr is a savage MC
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
oh you can go deeper. waaaay deeper, try [Only registered and activated users can see links. Click here to register]
or [Only registered and activated users can see links. Click here to register]
for example, custom diy controller with LED feedback (aka monolake-ish), complete integration with maxmsp over osc and all that shit. someone made a morphing preset switcher using the old live api code only (yep, the one from liveapi.org way back then), so yeah. start scripting why dont you
also, dont be afraid to share your setups and whatnots.
gbsr is offline   Thanks Reply With Quote
Old 05-05-2008, 11:14 AM   #23
BarracaMusic
BarracaMusic is currently spamming hard
BarracaMusic's Avatar
Valencia
HOT KEYS....when you want to add a midi/audio ch.
right click the mouse and there you have the listing for the keyboard commands.
It's usually ctrl+ something else
BarracaMusic is offline   Thanks Reply With Quote
Old 05-05-2008, 12:30 PM   #24
Synaecide
Synaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MCSynaecide is a savage MC
Synaecide's Avatar
"fuck my bile"
MC Status: 2727976
wow dude - thats a great guide. might sort through it properly when i've got some time. great work man.
youtube -- idmf --
Synaecide is offline   Thanks Reply With Quote
Old 05-05-2008, 03:57 PM   #25
BarracaMusic
Valencia
with Cubase you can program your own!!
I think it's in preferences under key commands.
have fun.
Old 06-05-2008, 05:08 PM   #26
gbsr
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
yeah.. OR read the keyboard command list in the manual.
Old 16-05-2008, 10:51 AM   #27
Magma
Magma will become famous soon enough
London
MC Status: 75
Thanks for this.. absolutely brilliant and exactly what I'm trying to get myself into at the moment. I spent an unhealthy amount of time last night creating templates for my RemoteZero!
Major respect!
Magma is offline   Thanks Reply With Quote
Currently Listening To: Bong Ra
Old 16-05-2008, 10:57 AM   #28
Synaecide
Synaecide's Avatar
"fuck my bile"
MC Status: 2727976
gbsr: you should put this into a PDF document.
youtube -- idmf --
Old 16-05-2008, 03:23 PM   #29
gbsr
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
nah. you should :p
Old 22-05-2008, 02:42 PM   #30
phading
phading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MCphading is a savage MC
phading's Avatar
Berlin
MC Status: 1503488
bah, I'm on a mac, using the IAC Driver, but I can't figure out the remote midi sampling part (which is the one i need)... Could any patient mind help me out? I got something close once, but it was really inaccurately annoying (It only gets the spikes).. Through your setup it just doesn't work out...
phading is offline   Thanks Reply With Quote
Old 22-05-2008, 08:45 PM   #31
gbsr
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
uh.
so whats the problem with it then?
cant really help you out if you wont give any details about your problem
Old 22-05-2008, 10:13 PM   #32
phading
phading's Avatar
Berlin
MC Status: 1503488
Yeah, i get ur point xD The problem is my english really sucks, I understand it well, but it's always a major problem to tell whats going in my mind >_<
Hmm, so let's try to explain this: My point in Ableton Live ain't really making a no-mouse set; I'm looking forward for a laptop+MIDI controller set.
But I think I'm missing something here. I don't need any midi translations for the midi sampling part, do I?
My situation: having my MIDI ports configured like yours (the only difference is that I use IAC Driver) I don't get any midi commands in my midi sampling track (i only get midi from notes). The "midi track in" lights (the ones in the corner) don't even flash when i turn a knob. I think I'm missing something; maybe I'm not even getting the point of this.. If you could explain better the routing of that I think I could work it out.
Old 25-05-2008, 03:47 PM   #33
gbsr
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
hm. have you set your controller up correctly?
remote control, and while youre at it you might aswell set it to track aswell.
also, is the midi track armed? it wont take any midi unless it is armed, and ofcourse set to the right channel (or omni heh).
if you still cant figure it out, could you perhaps throw up a screenie of the MIDI IO section (in live) and the track setup in session view. see if we take it from there heh.
Old 25-05-2008, 03:48 PM   #34
gbsr
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
oh and no, you shouldnt need any translators, the translators are mainly there to move the cursor around and hit enter and whatnots, so i just push a button to start resampling. if you are using your mouse anyways, it shouldnt matter at all.
Old 25-05-2008, 09:49 PM   #35
phading
phading's Avatar
Berlin
MC Status: 1503488
Thanks for ur support I think I did it all, but as soon as I get some free time I'll try it again and screenshot it.
Old 27-05-2008, 01:14 AM   #36
Thompsons
Thompsons is currently spamming hard
wow. thanks..
Thompsons is offline   Thanks Reply With Quote
Old 01-06-2008, 01:59 PM   #37
lolirl
lolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MC
lolirl's Avatar
MC Status: 744043891
Macros...?
WTF?
Nice one GBSR, i`m still sooo newb with this.
Point coming your way.
lolirl is offline   Thanks Reply With Quote
Old 01-06-2008, 02:51 PM   #38
gbsr
gbsr's Avatar
gothenburg, sweden.
MC Status: 33141603
cheers.
im thinking that i should propably continue this at some point, and/or clean it up a little.
right now im a bit too busy though.
Old 03-06-2008, 03:40 AM   #39
dualtrade
dualtrade is currently spamming hard
Sydney
Great work!! Definately looking to spend some "quality time" with my ableton.. When my Novation ReMote SL arrives!!
Thanks for the tips and links gbsr!
dualtrade is offline   Thanks Reply With Quote
Old 14-06-2008, 10:25 AM   #40
jlmh007
jlmh007 is currently spamming hard
Hi, My name is Luis, musician, I play latin.
This forum is interesting, congrats. I've been using my Boss DR-3 Drum machine for already 5 years, and I really love it, but the sounds are now a bit outdated, so I was hunting a replacement for it, but no drum machine available is as good as my DR3, even the new Alesis SR-18, I just read the manual and it is not enough for my purposes.
But now I am starting to see Ableton Live as a good replacement, I don't like the Idea of bringing a laptop to the stage, but for the sound quality It is whorty.
I play keyboard, the bass with the left and the rest wih the right, I am very familiar with drum machines, and I just programmed a couple of sets in Live 4. I have Midi's Bome translator as well, I use it for everything together with a Behringer BCN44 controller.
I will first build some sets with drum patterns in ableton live, and I will test them playing live. but there is some small features that are a bit different than my drum machine. For example, in the DR3 there is a tap tempo buttom, but I can press it how many times I want, the song will not start until I hit the start buttom, I will like this same feature in Ableton's Live, does somebody know any work around for this?
Thanks and congrats again !
Luis
jlmh007 is offline   Thanks Reply With Quote
Currently Listening To: everybody
