Acoustic Panels, Glue and Walls
Old 20-10-2017, 10:18 PM   #1
FoDriZZlE
FoDriZZlE has a spectacular aura aboutFoDriZZlE has a spectacular aura aboutFoDriZZlE has a spectacular aura about
FoDriZZlE's Avatar
MC Status: 210
Hello
Thinking about getting some acoustic panels, but Im wondering how this glue that comes with them work. Is it really safe to put it straight on the wall? How does this work? I dont want to make marks on my wall when I need to remove the panels.
FoDriZZlE is offline   Thanks Reply With Quote
Old 20-10-2017, 11:34 PM   #2
chasedobson
chasedobson's Avatar
Denver, CO
MC Status: 1540677
Re: Acoustic Panels, Glue and Walls
The glue will take the surface off of drywall, most definitely.
My solution was to affix the foam to lightweight masonite (? maybe thats not what its called) panels and hang those like picture frames.
Old 21-10-2017, 01:03 AM   #3
joem
MC Status: 20460
i used thosde sticky tiles you get from hardwhere stalls they work really well dont mess your walls up and stick to the foam nicely to
Thanks to joem
chasedobson (21-10-2017)
Old 22-10-2017, 09:51 AM   #4
FoDriZZlE
FoDriZZlE's Avatar
MC Status: 210
Can you tell me what tiles you used? Maybe link me a picture?
Old 31-10-2017, 02:16 AM   #5
Numerical
Numerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MC
Numerical's Avatar
Austin
MC Status: 45947281
Command Strips worked for me. Or that Scotch brand wall tape. Of course like chase said you gotta use lightweight materials. Masonite, thin rockwool etc. Just make frames and cover it with thin cloth you'd find at a place like Joann's or fekkin Hobby Lobby in the cloth dept.
brumski
Numerical is offline   Thanks Reply With Quote
