Anyone using Threadripper?
Technology & Lifestyle Gadgets, gaming, computers and new inventions. This forum is not used for music production.
Old 12-10-2017, 08:32 AM   #1
heydavid714
IDMf's latest spammer
heydavid714 is currently spamming hard
I just got mine setup and am enjoying it so far. Anyone else using it?
What's weird is that when I export audio... it doesn't really max out and push out the audio like I thought it would. I watch the CPU and it only goes at 25%. I wonder why FL Studio doesn't push the whole 100%.
heydavid714 is offline   Thanks Reply With Quote
Old 12-10-2017, 08:42 AM   #2
Vault O)))
Quarter pounder McCunt
Florida
MC Status: 52360
Re: Anyone using Threadripper?
Does that rip forum threads or something? (Yes, I'm out of the loop apparently)
Also, since this is your first post, welcum.
Old 12-10-2017, 02:37 PM   #3
A.M
IDMf SupporterIDMf Artist
A.M's Avatar
MC Status: 195610
I think he's talking about AMD's Ryzen Threadripper CPU.
AMD claim on their site, "Threadripper is simply the fastest multi-threaded processor on a consumer desktop PC, ever"
A recent PCWolrd review article seems to back up that statement in part..they say,"Threadripper blows away the Core i9 in multithreaded applications, such as rendering or video conversion. Meanwhile, the Core i9 performs higher on games and applications that are coded for single-threaded performance."
Thanks to A.M
Vault O))) (14-10-2017)
Old 12-10-2017, 03:34 PM   #4
joem
MC Status: 20460
yea i have used one the 1950x and yea its because fl studio isnt reading it properlly as its newer tech and dosent recognise it properlly also its only rendering on a few of the cors so not really needing to go 100 percent.
Also make sure you have xfr enasbled in the bios some mobos have that off by default.
Thanks to joem
A.M (12-10-2017)
Old 29-11-2017, 09:13 PM   #5
rmedhurst
rmedhurst is a glorious beacon of lightrmedhurst is a glorious beacon of lightrmedhurst is a glorious beacon of lightrmedhurst is a glorious beacon of lightrmedhurst is a glorious beacon of lightrmedhurst is a glorious beacon of light
rmedhurst's Avatar
MC Status: 510
Might be cos the Cpu has so many cores
:bye:
rmedhurst is offline   Thanks Reply With Quote
Old 01-12-2017, 11:45 AM   #6
Blingley
Madacu Sad Gent
Blingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MCBlingley is a savage MC
Blingley's Avatar
MC Status: 7237779
FL studio probably has support for 4 to 8 cores maximum. Consumer CPUs with core counts that high are not common, and have only been on the market for a short while. The support will come, though. OTOH I would be surprised if a more pro-studio oriented DAW such as Pro Tools didn't max it out when rendering.
Blingley is offline   Thanks Reply With Quote
Old 01-12-2017, 01:36 PM   #7
joem
MC Status: 20460
yea fl studio only reads core speed more than core count anyway. Even with multi thredded enabled, same with things like adobe creative sweet if you do a render and look at task manager at your core utlization youll see only one core working to make the render and the rest sort of idle, so yea nothing to worry about.
