A question about parallel compression
Old 16-12-2017, 11:35 PM   #1
pepehands
IDMf's latest spammer
pepehands is currently spamming hard
Icon5 A question about parallel compression
I have a question, I thought I had the grasp of parallel compression, but I was wrong because I didn't have a good understanding of the attack and release times of the compressor (I've been producing for almost 4 years, but the concept of compression has been one of the hardest for me to understand), so my question is, if you're using parallel compression on your drums, are you supposed to overcompress the transients of the drums by using a fast attack and a fast release or should you leave the transients as they are by increasing the amount of attack?
I know every situation is different, I'm not asking for specific numbers, I just want to know if I'm supposed to keep the transients or not? and do you know any books where I can get some detailed information about this and other methods?
pepehands is offline   Thanks Reply With Quote
Old 16-12-2017, 11:38 PM   #2
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8562280
Re: A question about parallel compression
My understanding of using parallel compression on drums (or anything really) is to bring out certain elements while maintaining the original material. So if you want to comrpess to get snappy transients, but want to leave the rest alone, that seems reasonable.
Honestly, i don’t know ton about the technicals of compression, I just use my ears mostly.
Thanks to relic
pepehands (16-12-2017)
Old 16-12-2017, 11:54 PM   #3
pepehands
Honestly, i donít know ton about the technicals of compression, I just use my ears mostly.
I mean, I use my ears too, but I'm digging on a mixing technique called "New York Compression" and this technique requires parallel compression, but the thing is that I don't get what's my goal, to squash the sound or to keep the transients.
I read about the technique on the book "the mixing engineer's handbook" by bobby owsinski, but he's quite vague about attack and release times on this kind of compression.
Old 17-12-2017, 12:13 AM   #4
Metaside
Metaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond reputeMetaside has a reputation beyond repute
Metaside's Avatar
MC Status: 8010
I often use various compressors and transient designers in parallel and series in a completely non-analytic and non-structured way, just based on what I felt at different points about improving the sound, so I might not be best suited to answer this, but imho you do the parallel thing especially in New York style compression so you can squash the hell out of the processed signal and mix it in softly while keeping the transients through the dry signal. But, of course, it depends.
Metaside is offline   Thanks Reply With Quote
Old 17-12-2017, 03:06 PM   #5
Iyashi Sound
Iyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond reputeIyashi Sound has a reputation beyond repute
Iyashi Sound's Avatar
MC Status: 9360
..and do you know any books where I can get some detailed information about this and other methods?
Bob Katz has an introduction to parallel compression in his book Mastering Audio (chapter 11 - part three: "the Lost Processes").
Iyashi Sound is offline   Thanks Reply With Quote
Old 17-12-2017, 07:33 PM   #6
Vault O)))
Buttcase
Vault O)))'s Avatar
St. Augustine
MC Status: 54210
I always thought mixing in the dry signal was supposed to make heavy compression more transparent / less noticeable
Thanks to Vault O)))
jbvdb493 (18-12-2017)
Old 17-12-2017, 10:44 PM   #7
pepehands
Welp, now that I understand a little bit more about this technique I think you use it to make sounds bigger and fat, without destroying the transients of, for example, your drums.
I've been messing around with this trick the last 3 days non stop to find the typical settings and the effects that it can do and I must say, it's pretty cool. Parallel compression by itself it's pretty cool, but if you want something more agressive you can go full "New York" style of mixing and add (after your compressor ofc) an EQ with a high and a low shelf both boosting the low and the high end by a lot (4db to 9db!) leaving you with a really bright and fat version of your dry signal
Old 17-12-2017, 11:04 PM   #8
liquid_air
liquid_air's Avatar
Corny
MC Status: 63260
Right, New York compression will make your sound fat. It uses short attack and short-med release to duck the transient and amplify the body. It will use high compression ratios to make it effectively a limiter for the transient but with high gain on the body. You mix it into the dry signal to taste.
Best way to think about compression is like a gizmo that is really fast in turning the volume knob in response to an incoming signal. Anything exceeding the threshold will be reduced in volume x-fold based on the ratio x set. Attack will define how quickly your gizmo will be lowering the volume and release how much it will lag in bringing the volume back up.
With ratios of 10:1 or higher, you are talking about a limiter. Infinite is a brick wall limiter. Use either one too much and your waveform will look like a shitty sausage with no dynamic range, like much of EDM or brostep. Itíll sound massive and like shit all at the same time.
Old 17-12-2017, 11:20 PM   #9
chasedobson
chasedobson's Avatar
Denver, CO
MC Status: 1541177
For NY style parallel compression you want to compress the "wet" side hard with slower attack times so that you keep the attack.
Often times with this method the compressed/wet side will also get an exaggerated eq so that one side (the wet side) is really loud and proud and then you'd mix in your dry side to taste so that the wet adds emphasis.
Thanks to chasedobson
Numerical (15-04-2018)
Old 18-12-2017, 01:28 AM   #10
jbvdb493
jbvdb493's Avatar
MC Status: 32360
That's the idea, I also use quite a bit of drive or distortion or actually fuzz is cool too for this, on the wet side, and try using compression in series too.
So you could have light comp on snare, another on the kick, etc. all going to a parallel bus driven and squashed and eqed to hell. Then all that blended and with a bit more bus comp on top of it all, it helps the dry and wet gel together a bit better.
Also you can use 2 different compressors in line with less comp on each and they affect each other, giving different character than just using one. (So 2 compressors with 2 dB reduction each instead of one with 4 dB.)
Or one pre eq and one post, or any other combination, just try it out.
Thanks to jbvdb493
pepehands (18-12-2017)
Old 18-12-2017, 01:48 AM   #11
pepehands
Yeah, I was thinking that you can get a lot out of this technique! those are some good ways of using it!
Right now I'm experimenting with some compression and EQ, but that thing with the 2 compressors in series is a good approach! I knew about a trick where you could use 2 limiters in series for mastering to add more character, but 2 compressors in parallel compression seem like a nice idea! thank you
Old 10-04-2018, 02:47 PM   #12
anmlsrmnml
Microknight
anmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond reputeanmlsrmnml has a reputation beyond repute
edinburgh
MC Status: 3302
Hey, with the attack you want to let through the transient and clamp down the release on the note value you wish.
I wrote up a blog post on it which may help
anmlsrmnml is offline   Thanks Reply With Quote
Old 10-04-2018, 05:49 PM   #13
Parricide
Parricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MC
Parricide's Avatar
MC Status: 18027769
it depends what you are going for. the point of parallel compression is to create the same affect that you would with more extreme settings (usually), but more subtle.
this could be that you are squashing the transient to push the tail more and create a bigger sound or it could be that you have a slow attack and you are letting the transient through while compressing the rest. either way, the point of parallel compression is to mix the processed version with the dry version in order to have a "happy medium" result
signature loading...
Parricide is offline   Thanks Reply With Quote
Old 11-04-2018, 09:43 AM   #14
HalfTrek
HalfTrek is a glorious beacon of lightHalfTrek is a glorious beacon of lightHalfTrek is a glorious beacon of lightHalfTrek is a glorious beacon of lightHalfTrek is a glorious beacon of lightHalfTrek is a glorious beacon of light
MC Status: 510
Mixing Audio by Roey Izhaki has a chapter (about 60 pages) about compressors in which he devotes a few to parallel compression. The binding on my copy is really bad though..falling apart. And sadly not from reading, more like keeping me from reading :/
HalfTrek is offline   Thanks Reply With Quote
Old 15-04-2018, 12:00 AM   #15
Vault O)))
Buttcase
Vault O)))'s Avatar
St. Augustine
MC Status: 54210
If you own it already, libgen probably has you covered for an intact version (no moral dilemma?)
Old 15-04-2018, 11:59 PM   #16
HalfTrek
MC Status: 510
Never even thought of getting a digital version. But trying to get it on my e-reader is not a bad idea. Quick search did not find anything though. Really great would be if the publisher provided a digital version with the book, probably not..but worth a look tomorrow
thx for the idea!
Mastering Question tristcarmichael The Studio 20 19-11-2017 12:52 PM
