Bass like basses
Old 03-10-2017, 01:05 AM   #1
jbvdb493
jbvdb493's Avatar
MC Status: 30460
Bass like basses
Silly title aside
I've been trying using ableton' tension (a plucked string physical modelling synth for those who don't know live) and running it through guitar rig 5 bass patches to make some cool, but still not quite real bass sounding, bass sounds.
Does anyone else know any tricks like that?
Not looking at anything too realistic as far as real bass guitars go, so not interested in sample based bass sounds, but something different and still a bit synthetic sounding.
Thx
Old 03-10-2017, 04:46 AM   #2
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8552330
Re: Bass like basses
Nothing like a simple mono synth patch with an envelope modulating the filter cutoff. I feel like no matter what sound you are going for nothing beats a single square wave. Whether its that classic hollow square bass or something a bit deeper more and more natural. I like 0 sustain, and decay/release too taste, but leave some tail to squash nicely with a compressor. Makes for a nice up front bass sound. I've been using the 1176 setting on Presswerk. I usually stack several distortion/saturation units (none 100% wet) and sculpt the sound just so. D16 Devastator and FabFilter Saturn having been making the rounds. Guitar Rig was is great as well, though I don't own it anymore.
Thanks to relic
jbvdb493 (03-10-2017)
Old 03-10-2017, 07:38 AM   #3
White Noise
White Noise's Avatar
California
MC Status: 23260
Not sure it's synthetic (if it's sampled it was a quick job) and I don't know if you can get it outside of FL Studio, but they've got one called Boobass that likes some compression/transient design to give it more dynamics. After that, I like Squashit or Decapitator for a similarly quick and easy distortion followed by my normal mixing chain (EQ, EQ, Reverb, EQ). Possibly do distortion before transient design.
Also, check this out. Updated 1-19-18.
https://www.facebook.com/JP4onthefloor/
Old 03-10-2017, 09:35 AM   #4
Vault O)))
Dumb jerk
Vault O)))'s Avatar
Florida
MC Status: 47660
I'm not sure how synthetic or sampled it actually is, but I used to run 4front's freeware bass VST into guitar rig for a semi-realistic sound. I felt like it was somewhere in between at the time, but I could be full of shit.
Honestly, even throwing cool analog / operator presets into GR could make for some interesting results that sound nothing like the source. Control room pro FTW
Old 03-10-2017, 04:43 PM   #5
chasedobson
chasedobson's Avatar
Denver, CO
MC Status: 1540027
Operator in Ableton, or any FM synth can get you really close.
In Operator:
Osc A: Coarse and fine at 1 and 0 respectively
Osc B: Coarse at .5 add in some volume to taste
Osc C: Set a really fast attack and decay to emulate a pluck and find a Coarse freq that works for what you are going for, like 3 or 4, you can add some fine adjustment to create more inharmonic overtones.
Thanks to chasedobson
Old 03-10-2017, 08:19 PM   #6
brb
brb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MCbrb is a savage MC
brb's Avatar
The Wrong Side Of History
MC Status: 69889269
Any noise or impulse or pulse of DC offset inputting to a MIDI controlled comb filter can sound bass string-like and very synthetic, so try that. Ohmygod and Melda's MComb would be my gotos.
:mayonesa:
brb is offline   Thanks Reply With Quote
Deeper bass in mix backtotape Sound Design, Mixing, & Studio Techniques 10 05-02-2018 10:44 AM
[metal crossbreed] SkullKore - Crossbreed your bass thanatos Listening Booth 1 01-10-2017 06:36 PM
New DNB Drum and Bass track for review cross-over Introduce Yourself 4 26-09-2017 06:48 PM
The Reese bass liquid_air Sound Design, Mixing, & Studio Techniques 3 08-09-2017 02:19 AM
remove bass from a track LDKitz Sound Design, Mixing, & Studio Techniques 8 03-09-2017 04:59 PM
