Connecting your iPad to run Apps as virtual VSTs
Old 06-08-2017, 02:02 PM   #1
liquid_air
liquid_air's Avatar
Corny
MC Status: 58510
Posted up recently regarding issues I've had connecting my iPad via an iConnect device. I came across this cool solution offered by [Only registered and activated users can see links. Click here to register]
It consists of a server program you run on your Mac or PC and a dedicated host app on the iOS device, both called Studiomux. You launch your IAA or Audiobus compatible app from that host software and you can use it like any old VST. You get 8 channels of audio plus one from your computer to the app.
It was a zero pain process, albeit not all apps are entirely compatible. Oh, and it's only $10.
Last edited by liquid_air; 06-08-2017 at 08:19 PM.. Reason: Link now fixed. Thanks AM
liquid_air is online now   Thanks Reply With Quote
Old 06-08-2017, 05:23 PM   #2
jbvdb493
jbvdb493's Avatar
MC Status: 30860
Re: Connecting your iPad to run Apps as virtual VSTs
I am glad you got something to work for you but it's still odd you can't get your iconnect to work.
Old 06-08-2017, 07:19 PM   #3
A.M
IDMf SupporterIDMf Artist
A.M's Avatar
MC Status: 190610
It consists of a server program you run on your Mac or PC and a dedicated host app on the iOS device. You launch your IAA or Audiobus compatible app from that host software and you can use it like any old VST. You get 8 channels of audio plus one from your computer to the app.
Just a heads-up..
You need to edit that link..it shows the ".com" in the post here, but when you click it, the ".com" is omitted and you are taken to a "Server not found" page.
iPad music making apps reticent Workstation Center 62 12-08-2017 06:15 AM
iPad apps? joem The Studio 19 22-10-2014 09:16 PM
iPad Apps that are Velocity Sensitive NaturalDissolve The Studio 13 27-08-2013 10:43 PM
IOS / iPAD Live performace apps scyn Workstation Center 32 03-04-2013 10:04 PM
ipad apps for ableton lorez The Studio 8 13-12-2012 05:49 PM
