Korg R3 vs Miniak
Old 16-06-2017, 09:45 PM   #1
oDDgOD
Soundscaper
oDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond reputeoDDgOD has a reputation beyond repute
oDDgOD's Avatar
Colorado Springs, CO
MC Status: 5810
Korg R3 vs Miniak
Im looking for a synth under $300 and my research points to the the MiniAK or the R3 as being close to what I want. I'm looking to get more into creating my own patches/editing presets and depending less on stock presets (though I'm not against using them). I also use step sequencing a lot, so I need a synth with a decent sequencer.
As I understand the MiniAK is a pain to edit and the vocoder isn't as good as the R3 but it sounds better. I'm not a huge fan of the Korg sound but I can work with it. I did like what I've heard of the miniak. Both have sequencers.
Anyone here have any experience with or a preference of the 2?
Are there other options I'm overlooking that would be a good fit?
Anybody can be good at something but it takes real effort to suck as bad as I do.
oDDgOD is offline   Thanks Reply With Quote
Old 16-06-2017, 10:19 PM   #2
jbvdb493
jbvdb493's Avatar
MC Status: 32460
Re: Korg R3 vs Miniak
No opinions on either, but I am curious why the need for a sequencer?
As opposed to using one you might already have?
Old 19-06-2017, 06:51 PM   #3
oDDgOD
Soundscaper
oDDgOD's Avatar
MC Status: 5810
I prefer to be able to compose on a piece of gear without needing other pieces. But I think, due to finances, I might finally start using some of the many free VSTs out there and just get a decent midi controller, (looking at the maudio axiom 25) while sticking with the qy-70 as my sketchpad/sequencer.
It wont have the portability I want, and I try to stay as out of the box as possible, but in the long run the music will benefit more.
Old 19-06-2017, 10:02 PM   #4
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8562380
Have you thought about the Korg Monologue? Dunno if you are looking for polyphony, but it sounds pretty damn good plus a step sequencer that allows knob movement recording : ) I really don't know either of those synths at all so... can't make a good alternative suggestion.
If you don't mind digital and want polyphony you might be able to get a Novation MiniNova for a decent price, not quite as nice to program as its big brother (UltraNova) but has some cool perfomance tricks up its sleeves.
Thanks to relic
chasedobson (30-06-2017)
Old 29-06-2017, 04:52 PM   #5
Geeogi
IDMf's latest spammer
Geeogi is currently spamming hard
i have experience only with the R3.
I find it very easy to use, and particularly easy to modify patches etc. The options for modifying are great too –I've always been able to modify the things i needed. Particularly with their step sequencer function which allows you to mod parameters using a recorded sequence of automation.
The r3 has a great sound. It sounds like a synth, not like a computer (a good thing). Though I don't find the sound quite as compelling as the Roland Gaia –that is a super fun synth.
The vocoder is great and super handy that the r3 comes with a goose neck microphone. Much easier to use than a mic stand etc.
On reflection, I would have bought a synth that has more knobs and buttons i.e. gaia or radias. With soft synths sounding better and better, the main factor which attracts me to using a synth is the fun factor of messing with the buttons.
Geeogi is offline   Thanks Reply With Quote
Old 11-08-2017, 01:07 AM   #6
Oldskooltekno
Oldskooltekno is a jewel in the roughOldskooltekno is a jewel in the roughOldskooltekno is a jewel in the rough
Oldskooltekno's Avatar
MC Status: 260
the Arturia Microbrute Analog Synthesizer sells for 300
has a step sequencer and has a lot of sound making shaping capabilities
the only thing is the keyboard is kind of small so only pretty much one octave .
Oldskooltekno is offline   Thanks Reply With Quote
Old 11-08-2017, 04:35 AM   #7
beautifulhurl
beautifulhurl is a jewel in the roughbeautifulhurl is a jewel in the roughbeautifulhurl is a jewel in the rough
beautifulhurl's Avatar
Baltimore
MC Status: 260
The Miniak is pretty strong, it has the same engine as the Alesis Micron. I ended up selling it because it felt like I was diving through menus too often, and it ended up being a bit too heavy for my rig at the time, as it was surprisingly heavy. That said, it can do a lot, and it has some interesting filters, so you could find it perfect for a lot of different purposes.
beautifulhurl is offline   Thanks Reply With Quote
Korg Volca Beats vs Korg Monotribe professurreal Hardware and Gear 11 18-05-2014 10:00 PM
Korg D_Davis Hardware and Gear 24 01-03-2014 10:50 AM
7 bar loop - Miniak x 404 FunkMasterBrown Listening Booth 0 18-09-2013 03:33 AM
Korg M1 reticent Workstation Center 44 05-01-2013 12:18 AM
MiniAK questions? Zalgo Hardware and Gear 2 16-01-2012 04:04 PM
