Can you make pro mixdown with cheap plugin and why you should
Closed Thread
Old 20-08-2016, 04:22 PM   #1
thanatos
Master of the LFO
thanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MC
thanatos's Avatar
MC Status: 733536
in short tl dr the answer is yes so try harder
and also mixdown is artistical esthetical choice so keep it to you
longer
thanatos is offline   Thanks
Old 20-08-2016, 05:37 PM   #2
mnkvolcno
mnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MCmnkvolcno is a savage MC
mnkvolcno's Avatar
MC Status: 29660
Re: Can you make pro mixdown with cheap plugin and why you should
Hi there. Pretty good points here.
However, I think you might want to get someone who is a bit stronger with English to proof read this. There are several errors.
Also, the bit about mastering is err... Pretty bad. -3 or -6 db rms is insane. Personally I prefer things at -12 or less. I don't even think it's possible to master at -3db rms lol.
mnkvolcno is offline   Thanks
Old 20-08-2016, 06:21 PM   #3
Evelon
Evelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MC
Evelon's Avatar
MC Status: 214390098
That was vague, weird, simplistic, erroneous and overall...
Sorry.
Evelon is offline   Thanks
Old 21-08-2016, 01:18 AM   #4
joem
MC Status: 20560
hes has a few points though ive had a few releases on smaller labels where ive done tracks useing fruity stock plugins, mixed masterd etc all in fruity loops but yea -3db master is a bit excessive.
joem is offline   Thanks
Old 21-08-2016, 03:42 AM   #5
Narukami Music
Master of the LFO
Narukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MCNarukami Music is a savage MC
Narukami Music's Avatar
MC Status: 10160
The idea of this post is good. I personally believe that you can make anything sound great with stock/free plugins if you know what you're doing. Not a bad message to send to people, I think.
But the article itself is a bit... meh. It oversimplifies things and you don't really go as in depth as I think you should. The mixdown and the mastering part, I personally disagree with. Mixing is both art and a science. You can use whatever EQ, compressor, delay or reverb you want but if you don't understand what you're doing, it's not gonna help. And that mastering point? -6 to -3RMS?? That's excessive, dude. Too loud, in my book.
But I guess the last thing to note is that you don't even talk about mixing with cheap plugins. You talk about everything else except plugins, lol. If the point of this article is to get people to be more confident with stock/free plugins, you should probably talk about them.
Also, as someone else stated, get someone to proofread your articles dude. Lot's of spelling mistakes. I get that English isn't your first language but I think randoms who come across your articles will be confused.
Not trying to be an asshole here. Just sharing my thoughts.
Narukami Music is offline   Thanks
Old 21-08-2016, 05:10 AM   #6
A.M
IDMf SupporterIDMf Artist
A.M's Avatar
MC Status: 198360
The thing about this topic is if you're asking, then it's safe to say you don't know shit about mixing..otherwise you would automatically know it doesn't matter what plugs you use, as long as you know what they do and how to use them.
There's one caveat in regards to limitations..basically, when using free plugs, you need to make sure they're good and actually work. There's more than a few free ones out there that do feck all or are total shite and not worth downloading!
If using free plugs is something you want to try or have to do out of necessity, then I'd suggest you learn as much as you can about EQ and Compression..and I don't just mean read up on them..get your hands dirty by messing around with test tracks, so you can get real "hands-on" experience..it's the only way to really lean these things..seriously.
Forget about mixing or mastering until you've got a handle on both techniques..otherwise you're just wasting your time.
A.M is offline   Thanks
Old 21-08-2016, 11:28 AM   #7
ms_
ms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MC
ms_'s Avatar
MC Status: 123160
Every DAW is packed with everything you need to make a decent mixdown and even do mastering. It's all about skill and knowing how to use plugins you already own more efficiently. You start looking for alternatives if you feel that those plugins aren't that great and you want something more out of them; I'm talking about factory/stock tools. However, what mostly you need for mixdown is EQ and stock ones usually do their job just fine.
edit: wtf is this article about
ms_ is offline   Thanks
Old 24-08-2016, 01:03 PM   #8
TheSampleThief
Microknight
TheSampleThief is a splendid one to beholdTheSampleThief is a splendid one to beholdTheSampleThief is a splendid one to beholdTheSampleThief is a splendid one to beholdTheSampleThief is a splendid one to beholdTheSampleThief is a splendid one to behold
TheSampleThief's Avatar
MC Status: 660
I thought there would be some sort of a guide or sth.... I don't really get the point of this thread otherwise.
TheSampleThief is offline   Thanks
Old 25-08-2016, 02:01 PM   #9
thanatos
Master of the LFO
thanatos's Avatar
MC Status: 733536
the point is that if your mixdown sucks it's because you don't know what you do. Expensive hardware won't make good mixdown by magic
to learn technique check the producer page on the webzine especialy the gain staging tutorial
Thanks to thanatos
A.M (25-08-2016)
Old 27-08-2016, 08:49 PM   #10
LustHouse
Analog Lurker
LustHouse is a glorious beacon of lightLustHouse is a glorious beacon of lightLustHouse is a glorious beacon of lightLustHouse is a glorious beacon of lightLustHouse is a glorious beacon of lightLustHouse is a glorious beacon of light
MC Status: 510
Depending on what you really mean by "pro mixdown". I'd say quality of your speakers/headphones is more important than "quality" of your daw.
LustHouse is offline   Thanks
Old 28-08-2016, 11:54 PM   #11
Roo Stercogburn
IDMf SupporterIDMf ArtistAdministrator
Roo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MC
Roo Stercogburn's Avatar
On horseback
MC Status: 42401799
Hey lets make people learning feel worse about themselves.
IDMf: Outside of porn, best cunts on the internet.
Roo Stercogburn is offline   Thanks
Closed Thread
Any Mixdown tutorials 1BadMouse81 Sound Design, Mixing, & Studio Techniques 2 02-05-2016 04:26 PM
DIY cheap unique spring reverb. (follow up to how to make cheap contact mic) Adipher Sound Design, Mixing, & Studio Techniques 1 01-04-2013 10:06 PM
Looking for some input on my MIXDOWN. ch0kshsa Listening Booth 2 08-10-2011 10:46 PM
How is this mixdown? Tvds Sound Design, Mixing, & Studio Techniques 6 06-09-2011 07:36 PM
Visual Mixdown andrewsp88 Sound Design, Mixing, & Studio Techniques 1 02-09-2011 06:59 PM
