Cakewalk SONAR is dropping numbered version releases - Page 8
Old 11-08-2015, 12:09 PM   #141
candlesayshi
Imperfect
candlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MC
candlesayshi's Avatar
Chicago
MC Status: 39281549
Re: Cakewalk SONAR is dropping numbered version releases
Originally Posted by Stercogburn View Post
Cakewalk summer sale.
Snagged the Pro Channel Concrete Limiter for £16.
It is rather awesome.
Yeah, I think I'm going to pick that up, too. Been also looking at the PC4K Expander/Gate which is also $20 at the moment...
candlesayshi is offline   Thanks Reply With Quote
Old 11-08-2015, 03:23 PM   #142
Str8Jaketed
Str8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MCStr8Jaketed is a savage MC
Str8Jaketed's Avatar
GET OFF MY LAWN!
MC Status: 33010
the ProChan modules are beauts..love them..all I have left to get are the VFX ones but I might pass on those since I have so much other crapola that doe the same thing but teh Pro Chan keeps things nice adn tidy so I am still on the fence.
“A composer is a guy who goes around forcing his will on unsuspecting air molecules, often with the assistance of unsuspecting musicians.”Frank Zappa
“Hell is full of musical amateurs.” -George Bernard Shaw
Str8Jaketed is offline   Thanks Reply With Quote
Old 18-08-2015, 11:52 AM   #143
Roo Stercogburn
IDMf SupporterIDMf ArtistAdministrator
Roo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MC
Roo Stercogburn's Avatar
On horseback
MC Status: 42401849
Found another 'feature'.
If you assign Melodyne to a clip, afterwards you can no longer use automation on the gain to change the volume level. It simply doesn't work, even though you can draw your envelope as normal. I've tested and confirmed this separately in different projects.
IDMf: Outside of porn, best cunts on the internet.
Roo Stercogburn is online now   Thanks Reply With Quote
Old 26-08-2015, 07:44 PM   #144
candlesayshi
Imperfect
Chicago
MC Status: 39281549
Went to check the Rolling Updates page after the notification that the new update was available, and saw this in the upcoming features list:
Intriguing. Wonder what that's about.
Old 09-09-2015, 07:36 PM   #145
Roo Stercogburn
On horseback
MC Status: 42401849
Hopkinton update. Back into Demo Mode and offline activation will not return it to full working order. THIS IS AFTER A FULL CLEAN INSTALL THROUGH COMMAND CENTER.
Hate hate hate LOATHE hate hate DESPISE hate hate hate.
Twats can't do meta to save their bloody lives.
Old 11-09-2015, 12:52 AM   #146
candlesayshi
Imperfect
Chicago
MC Status: 39281549
You have the worst luck, Stercogburn...
Old 11-09-2015, 07:32 AM   #147
Roo Stercogburn
On horseback
MC Status: 42401849
I am not sure how it fixed it, but running the Hopkinton update again made Sonar work. When this happened to me before (posted earlier in this thread) both my serial number and name were gone from the registry entries under Cakewalk. This time they were still there. Running the update again was just filling time while I tried to figure out what was going on. And it worked.
What I'm trying to figure out next is why Reaktor 6 breaks Sonar. I have a lovely template I've built up with all my little bits and pieces laid out how I like it and with my default soft synths loaded. If I load Reaktor 6 into it, the CPU goes nuts. What I notice is that the one CPU hits red but the others are not particularly in use.
If I load a blank project and put Reaktor 6 into it, Reaktor 6 plays without any glitching but still shows extremely high CPU usage. Once again though, all the pressure is on one core.
Old 29-11-2015, 09:57 PM   #148
candlesayshi
Imperfect
Chicago
MC Status: 39281549
Any of you download the Rapture Session instrument with the new update? What do you think?
I had skipped over the Rapture Pro upgrade, because even though I use Rapture a fair amount still, I really only ever was using Dimension Pro for the pretty nice fake strings after a while. Then, hardly at all after I'd opted to just record cello and violin parts instead. So, though I like the idea of making them one instrument, I wasn't sure if I'd really need it.
Sidenote: Love the Aux Tracks and Patch Points that were added in the previous update. Immediately awesome and useful.
Old 29-11-2015, 11:01 PM   #149
Roo Stercogburn
On horseback
MC Status: 42401849
Rapture Session just seems to be a player so I don't think I'll be using it much since I already have Rapture Pro. Nice idea to make a player though, since obviously it will use less CPU if that's a factor on someone's system. Create the sound in Pro, make it available in Session, or if you use it to play live, handy to have a cut down version of Pro.
I feel like I'm making excuses for it. Moving on
I did get Rapture Pro some time ago but wasn't initially impressed with it and its lo-rez crappy interface. This update seems to have fixed the interface somewhat. Pro does have a big library of wavetable sources and its fun playing around with these - even just dropping some into the presets to see how they change.
But... I can't shake the feeling that there's nothing it can do that Massive, Z3ta+2 and Omnisphere can't do better.
Old 02-12-2015, 08:00 PM   #150
candlesayshi
Imperfect
Chicago
MC Status: 39281549
Hmmm.... Yeah, I imagine so.
Old 18-12-2015, 07:01 PM   #151
candlesayshi
Imperfect
Chicago
MC Status: 39281549
The new update hasn't even come out yet, but I'm already sick of "Style Dials"
Old 13-01-2016, 08:08 PM   #152
candlesayshi
Imperfect
Chicago
MC Status: 39281549
Next update looking like it might be a stormer:
Old 13-01-2016, 08:42 PM   #153
Roo Stercogburn
On horseback
MC Status: 42401849
Yeh, they'll need something good to keep people subscribing for another year of updates.
I love that they say Melodyne 4 will integrate seamlessly 'as always'. Although working now, when originally bundled it was an utter clusterfuck and you still have no control over where it installs
Old 25-01-2016, 01:18 PM   #154
Roo Stercogburn
On horseback
MC Status: 42401849
Melodyne 4 Essential is now available for Sonar. Installed it but didn't play with it as I got distracted by writing musics rather than checking it out.
Old 27-01-2016, 12:11 AM   #155
Roo Stercogburn
On horseback
MC Status: 42401849
Manchester update for Cakewalk:
Aaaaaand another broken Cakewalk update. Select All. Click a bar, Click "Set From= Now". Click another bar. Click "Set Thru = Now". Click Edit, Delete Special, select all options and make sure "Delete Hole" is selected. Any track that doesn't have any content within the area selected to be deleted does not move. The entire project goes out of sync with itself unless you click undo or move tracks manually.
/golf clap Gibson.
Muppets
Old 03-02-2016, 12:29 AM   #156
Roo Stercogburn
On horseback
MC Status: 42401849
More flakiness. Lost an entire automation lane on a track that I hadn't even edited other than to delete one section.
Old 04-02-2016, 01:31 AM   #157
Roo Stercogburn
On horseback
MC Status: 42401849
Interesting, another 'Manchester' update.
Downloaded and applied it but won't be testing this evening.
Old 07-02-2016, 04:56 PM   #158
Roo Stercogburn
On horseback
MC Status: 42401849
Can't copy audio sections with Melodyne applied. As soon as I press CTRL+C it crashes Sonar completely.
Old 23-02-2016, 11:54 PM   #159
Roo Stercogburn
On horseback
MC Status: 42401849
Confirmed this tonight with a completely new project made from scratch, so its not corruption in an existing project. However, I've just this second noticed there's a new update for Sonar, I'll check to see if its fixed. Fingers crossed.
EDIT:
Still bugged after update. Doesn't happen in every project. No idea what the criteria are for making it crash Sonar.
Old 24-02-2016, 01:35 AM   #160
candlesayshi
Imperfect
Chicago
MC Status: 39281549
Ah yeah! I forgot a new update came out today. Still waiting for the Mastering FX updates, but the Add Track thing is a nice add, I think.
Cakewalk Sonar X3? Roo Stercogburn Workstation Center 65 09-01-2014 05:08 PM
Cakewalk announces SONAR X2!!! candlesayshi Workstation Center 25 15-03-2013 10:53 PM
Getting Cakewalk Z3TA +2 to work in Ableton gammarang Workstation Center 6 03-11-2012 08:59 PM
Cakewalk Sonar X1: Cut'n' Paste Automation Roo Stercogburn Workstation Center 9 02-11-2012 08:58 PM
[Breaks/Techno] Online Mixing Service version Vs. My version modescmoesc Listening Booth 8 07-12-2011 11:31 PM
