Roland Aira System One
Old 16-08-2016, 06:22 AM   #1
floydianslip
Radial Developer
floydianslip is a glorious beacon of lightfloydianslip is a glorious beacon of lightfloydianslip is a glorious beacon of lightfloydianslip is a glorious beacon of lightfloydianslip is a glorious beacon of lightfloydianslip is a glorious beacon of light
floydianslip's Avatar
MC Status: 510
Anybody else out there have the Aira System One plug-out synth by Roland? I know it came out not so long ago so my hopes aren't high. Anyhoo, I bought mine a few months ago and have been very happy with it, but last week it ceased working as a midi controller. I am really hoping it's not broken and I'm just doing something wrong. Anybody out there run into the same issue or a similar one? My driver settings are definitely correct and I see signal in reason when I hit the keys, but hear nothing and record nothing.
floydianslip is offline   Thanks Reply With Quote
Old 16-08-2016, 07:02 AM   #2
Sons of Achab
Sons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond reputeSons of Achab has a reputation beyond repute
Sons of Achab's Avatar
In a beautiful place out in the country
MC Status: 4160
Re: Roland Aira System One
I use the system-1 for one year now with Ableton Live and I never had a problem. If you are using it with the plug-out running in Reason be sure that the "setting" window of the vst is correctly configured. You have to select "SYSTEM-1 CTRL"in the midi IN / midi OUT boxes if you are using windows or "SYSTEM-1" if you are using Mac OS.
Soma
Sons of Achab is offline   Thanks Reply With Quote
Old 16-08-2016, 03:47 PM   #3
White Noise
White Noise's Avatar
California
MC Status: 23260
Make sure everything is plugged in and set up before firing up your daw. I can't so much as unplug my headphones once my daw is running or the whole thing will crash, same for midi controllers (needless to say, it doesn't recognize them when I plug them back in either).
Old 16-08-2016, 04:32 PM   #4
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8553180
Are you serious about your headphones? Because that honestly sounds absurd. Something is wrong w your setup if unplugging headphones makes your daw crash...
Old 16-08-2016, 09:33 PM   #5
White Noise
California
MC Status: 23260
Not to get off topic, but I think it's because I run them through a USB dac, so if that comes unplugged, my PC is switching audio outputs from digital to analog and that trips up my daw. It's inline with my headphones, so I pretty much think of it as a single unit, but it's the USB dac coming out.
To the OP, have you kept the synth clean/dust free? I don't know if it would mess up a keyboard, but dust messes up turntables in my experience, pretty easy to clean with some electronics cleaner in a can.
Thanks to White Noise
relic (16-08-2016)
Old 23-08-2016, 01:24 PM   #6
bIOtAPEstry
Microknight
bIOtAPEstry is a name known to allbIOtAPEstry is a name known to allbIOtAPEstry is a name known to allbIOtAPEstry is a name known to allbIOtAPEstry is a name known to allbIOtAPEstry is a name known to all
bIOtAPEstry's Avatar
Sydney
MC Status: 610
Just got a Street Cub EX.....
Its sick. 50 watts of tank like monitor. Mmmmmmmm
Please like my Facebook page!!
https://www.facebook.com/nomadicjurassic
bIOtAPEstry is offline   Thanks Reply With Quote
Old 04-09-2016, 07:34 AM   #7
floydianslip
Radial Developer
MC Status: 510
Thanks for the ideas guys. The synth is not dusty (I keep it in its original box when not in use), and the vst settings described are the ones I've been using. I tried plugging in before starting up my DAW and still had the same problem. Given all of this info, sadly I am going to assume that either my synth or my pc is broken (working with a 6 year old HP pavillion here, not ideal).
Old 25-04-2017, 03:19 AM   #8
floydianslip
Radial Developer
MC Status: 510
Update: The synth no longer makes sound in manual mode, only in the preset modes, but the preset modes are now affected by all of the controls. To give an example; if say, the bit crusher knob is up when I first enter a preset, I will hear the effects of the knob on the preset, whereas previously I would have heard just the preset by itself, and would only begin to hear the crusher if I physically moved the knob, even if it was set to maximum. Has anyone ever had this problem? I am really hoping that it isn't broken, but my hopes are not high at this point.
mfb-522 vs. Roland 707 docbrown Hardware and Gear 7 29-01-2015 05:49 PM
Roland AIRA Series Stich Hardware and Gear 9 21-03-2014 02:37 PM
Roland AIRA (Evolution of the TR-808) lolirl Hardware and Gear 145 27-02-2014 05:45 PM
Roland CMU-800 D_Davis Hardware and Gear 3 15-05-2012 07:11 PM
Roland TR-505 Loonic Hardware and Gear 17 23-12-2011 11:41 PM
