A Good Hardware Synth for Under 500 - Page 3
Old 20-08-2012, 03:11 PM   #41
lolirl
lolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MClolirl is a savage MC
lolirl's Avatar
MC Status: 744043391
Re: A Good Hardware Synth for Under 500
I'll say it one more time here.
Microkorg + decent midi controller = ms2000++++
lolirl is offline   Thanks Reply With Quote
Old 20-08-2012, 03:16 PM   #42
RFJ
IDMf ArtistModerator
RFJ's Avatar
I live in California.
MC Status: 199648418
I'll say it one more time here...
Microkorg + decent midi controller = same price as used MS2000r.
So why not just get the real thing?
Old 20-08-2012, 03:16 PM   #43
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8564530
Originally Posted by RFJ View Post
I don't doubt that you will get less latency with a proper interface, if that's what you're saying, than you will with a midi to USB cable but isn't the midi signal routed thru USB either way because the interface is ultimatly being connected to the PC via USB?
:ph34r: Fuck...you are right...I was thinking my old PCI soundcard that had MIDI...fuck me...ignore everything I said about MIDI cables/interface Mystik...
although if I can save face a tiny bit...USB MIDI cable isn't a bad purchase IMO...especially if you are planning on more gear...
*insert gear junkie warning* and *gear acquisition syndrome (GAS) warning*
Old 20-08-2012, 04:21 PM   #44
Delinquent Dialect
Sample Destroyer
Delinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MCDelinquent Dialect is a savage MC
Unregistered's music is self indulgent nonesense!
MC Status: 25172146
Originally Posted by _Mystik_ View Post
man, theres so many options! lol i was also looking at a yamaha dx7, but i already have fm8, which is designed after the dx7.
You dont want a DX7.
<< dont listen >>
if ( mind == open ) {""}
Latest vinyl "Purging the Pious" EP from Earwiggle Records https://www.facebook.com/earwigglelabel
Delinquent Dialect is offline   Thanks Reply With Quote
Old 21-08-2012, 07:57 AM   #45
lolirl
lolirl's Avatar
Er...because you can use one controller with multiple MIDI devices, that's why smart guy.
Wtf is wrong with people these days?
MIDI is great, use it.
Old 21-08-2012, 07:58 AM   #46
zyklon
zyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant futurezyklon has a brilliant future
zyklon's Avatar
Edinburgh
MC Status: 1510
The MS2000r has MIDI out and so can presumably be used as a controller.
zyklon is offline   Thanks Reply With Quote
Old 21-08-2012, 08:04 AM   #47
lolirl
lolirl's Avatar
Buy an MS2000r to control your Microkorg?
Old 21-08-2012, 08:17 AM   #48
zyklon
zyklon's Avatar
Edinburgh
MC Status: 1510
No. If you are intending on buying a Microkorg + a MIDI controller for the extra parameters, you may as welljust buy an MS2000r for roughly the same price and functionality, with the added convenience of having it in a single unit with all the parameters preassigned and laid out logically for that synth engine.
You're not at any greater advantage having a MicroKorg + seperate MIDI controller, because you can use the MS2000r to control other devices too.
Old 21-08-2012, 02:02 PM   #49
lolirl
lolirl's Avatar
Indeed.
However, if like most newcomers to electronic music these days you've already bought a MIDI controller before your first hardware synth then you'd do well to save yourself some cash and get 75-80% of the functionality of the ms2000r at a much reduced cost (since you only need to buy the micro).
Using a dedicated hardware synth such as the MS2000 or Nord is certainly possible, but often just causes hassles.
If for example you're using voices from that synth at the time then you're going to be tweaking those simultaneously when you're simply trying to control your other device, unless of course you can somehow "detach" the controls from the internal synth.
I'm not sure if that's possible with the MS2000r tbh, I know the microkorg has a "local" mode, but I'm pretty sure it's not possible with the nord.
Old 21-08-2012, 02:36 PM   #50
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8564530
Considering you can get a decent MIDI keyboard for almost nothing (IMO)...I'd go MS2000R + MIDI keys
but that is just my spend thrift opinion : )
Old 21-08-2012, 02:40 PM   #51
_Mystik_
Your Secret Admirer
_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC_Mystik_ is a savage MC
_Mystik_'s Avatar
Rhode Island
MC Status: 11210
well i already have a midi controller, so thats not a big deal. hows the waldorf blofeld?
SyMTiK
Berklee College of Music '21
_Mystik_ is offline   Thanks Reply With Quote
Old 21-08-2012, 02:41 PM   #52
zyklon
zyklon's Avatar
Edinburgh
MC Status: 1510
It's also worth considering the resale value if you ever want to get rid of it. MS2000s are increasingly rare and desirable. MicroKorgs are so common that in 10 years time they will be pretty much worthless.
The Waldorf Blofeld is a really amazing synth, especially for money. The interface/screen more than makes up for the lack of knobs. I would, however, recommend listening to a LOT of demos before getting one. It's unashamedly digital, and has quite a brittle, unique quality to the sounds you'll get out of it, which I love, but it isn't for everyone.
Old 21-08-2012, 02:42 PM   #53
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8564530
Blofeld is supposed to be pretty awesome. It's on my very long list of possible purchases. D_Davis/Carl Sagan's Ghost loves it...I respect his opinion pretty well at this point. It doesn't have a lot of dedicated controls.
BTW, if you have a set of keys already...I'd say MS2000R there are a bunch of stupid cheap ones on eBay as of last night.
Old 21-08-2012, 02:45 PM   #54
_Mystik_
Your Secret Admirer
_Mystik_'s Avatar
Rhode Island
MC Status: 11210
i heard that it can reproduce similar sounds to that of ni massive, and i use massive for a lot of my sounds. it also looks pretty simple, which is good for someone like me who likes things being easy to use, i cant stand spending hours trying to figure out how to even make a sound.
SyMTiK
Old 21-08-2012, 02:47 PM   #55
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8564530
i heard that it can reproduce similar sounds to that of ni massive, and i love using massive. it also looks pretty simple, which is good for someone like me who likes things being easy to use, i cant stand spending hours trying to figure out how to even make a sound.
Look at what you are saying though "I love using Massive" and "It's supposed to make sounds like Massive" Too really different things...how it works versus how it sounds. Just saying.
Old 21-08-2012, 02:47 PM   #56
_Mystik_
Your Secret Admirer
_Mystik_'s Avatar
Rhode Island
MC Status: 11210
yeah i saw that, the most expensive one at the moment is only 400, which is right under my budget. a used blofeld is around 500 tho, very tempting.
SyMTiK
Old 21-08-2012, 02:48 PM   #57
_Mystik_
Your Secret Admirer
_Mystik_'s Avatar
Rhode Island
MC Status: 11210
i meant i like using it because it can make good sounds, not how it works, altho it is very easy to use.
SyMTiK
Old 21-08-2012, 02:50 PM   #58
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8564530
Don't buy a synth on a budget, at least not for a first one. My first piece of hardware was my ESX...and I went ahead and spent the money because it was what I wanted and I'm like stupid giddy about that box still and I've had it all summer. The honeymoon is over and we got down to some serious programming : )
In the end, many of these boxes we are talking about won't loose much if any value if you take care of them.
Edit: I see what you are saying about Massive.
Last edited by relic; 21-08-2012 at 02:50 PM.. Reason: people post too fucking fast
Old 21-08-2012, 02:51 PM   #59
bbb
bbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MCbbb is a savage MC
bbb's Avatar
ATX
MC Status: 5746293
The Blofeld is first on my list actually. The dedicated knob issue might be a little tricky but I'm not a huge knob twiddler while playing stuff, so I'm not that concerned. I think the thing has 1000's of presets, if I remember correctly. Things are visually represented on the screen.
They're going for pretty cheap on ebay, I think the lowest I've seen is $550 for a desktop unit. If I ever buy one finally, I'll say how I like it or not.
Say :|
bbb is offline   Thanks Reply With Quote
Old 21-08-2012, 02:53 PM   #60
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8564530
All this fucking hardware talk is going to rape either my checking account or billmelater account in about three seconds!
More hardware synth questions.... modescmoesc Hardware and Gear 5 26-07-2012 11:32 PM
hardware synth(techno/tech house) liquidbass Hardware and Gear 13 12-06-2012 04:25 AM
Is this bass sound from hardware or soft synth? mic3756 The Studio 8 17-03-2012 01:42 AM
How to Control my Hardware synth with a Midi Controller? WillyZi Hardware and Gear 22 11-11-2011 05:38 AM
Decent first hardware synth rewriter The Studio 27 11-10-2011 07:52 PM
