Best way to sustain echo/delay
Old 07-01-2017, 04:12 PM   #1
Bluesh1ft
Sample Destroyer
Bluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond reputeBluesh1ft has a reputation beyond repute
Bluesh1ft's Avatar
In another world, usually
MC Status: 2660
Hi All, I am trying to get that effect where you finish a phrase and there is delay/echo on it but it continues to echo and then you use that delay as part of your build up for a drop or something else. Whats the best way to achieve this? Thanks in advance. Edit: Ah so using the feedback knob works and then raising the volume of the echo effect, but im curious if there are any other methods.
Bluesh1ft is offline   Thanks Reply With Quote
Old 07-01-2017, 05:23 PM   #2
Focalized
Man in the box
Focalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MCFocalized is a savage MC
Focalized's Avatar
Space Base
MC Status: 10377967
Re: Best way to sustain echo/delay
In your DAW you have complete control of this. Use some volume control.
Focalized is offline   Thanks Reply With Quote
Old 07-01-2017, 05:39 PM   #3
Artificer
Ghostly
Artificer's Avatar
Southern Hell
MC Status: 35060
Yeah, you generally use the Feedback setting for that as it's what determines the decay time of repetition. In most digital delays a hard 100% is just going to keep going until you stop it (a la sample/hold), so you can use that to just repeat out forever if you like.
You could also record the delay/echo tail and then actually copy/paste it to continue repeating as a separate element. That would offer you a lot more control over it, though it'd be more time consuming than twisting a few knobs.
Artificer is online now   Thanks Reply With Quote
Thanks to Artificer
chasedobson (07-01-2017)
Old 07-01-2017, 06:15 PM   #4
chasedobson
chasedobson's Avatar
Denver, CO
MC Status: 1540077
^ this.
Old 07-01-2017, 06:37 PM   #5
Artificer
Ghostly
Artificer's Avatar
Southern Hell
MC Status: 35060
I'll also suggest that if you don't know what the knobs and buttons do on your equipment (virtual or otherwise) it's worth looking it up. A quick google or youtube search for 'delay feedback settings' gets you a whole host of explanations.
You don't need to know that the feedback setting originally referred to forcing an electrical signal through a separate circuit to repeated force a new boost in the signal, but you should know that, in the case of Delay:
Time - time between repeats
Feedback - amount of repetitions
Level/Volume - volume of repeats
Mix - wet/dry mix between original signal and the effected one
Knowing all that it's easy to dial in anything from a slapback to freaky space rock. The same goes for stuff like ADSR or phase/flange/chorus effects. While random knob-twisting is fun and great for happy accidents and experimentation, it's not very conducive to quickly getting a specific sound. Putting a little time in learning how stuff works under the hood can often save time in the long run.
Old 08-01-2017, 01:28 AM   #6
White Noise
White Noise's Avatar
California
MC Status: 23260
I've seen some delays and reverbs with a freeze button, which continuously repeats the delay until it's disengaged, so then you don't even have to bother with getting feedback set up right, you can just automate the freeze parameter.
Also, check this out. Updated 1-19-18.
https://www.facebook.com/JP4onthefloor/
Old 08-01-2017, 01:37 AM   #7
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6905759
Feedback loop.
Put the delay on a send and then route it into itself.
Once you have a nice tail, tweak with the send amount and try not to blow your brains out.
Thanks to Jaded
jbvdb493 (13-01-2017)
Old 08-01-2017, 01:38 AM   #8
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8553030
Use a limiter to protect your gear/ears.
Old 08-01-2017, 04:31 AM   #9
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6905759
Limiters are for wimps. Redlining and digital clipping is where it's at in 2017!
Old 08-01-2017, 05:24 AM   #10
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8553030
Deafness and blown speakers 2017
Thanks to relic
D42K732202 (13-01-2017)
Old 13-01-2017, 06:15 PM   #11
thanatos
Master of the LFO
thanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MCthanatos is a savage MC
thanatos's Avatar
MC Status: 733536
compression and soft clipping can shape delay
thanatos is offline   Thanks Reply With Quote
Old 13-01-2017, 08:27 PM   #12
Evelon
Evelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MC
Evelon's Avatar
MC Status: 214390048
...and pitch shift, pre feedback.
Evelon is offline   Thanks Reply With Quote
Thanks to Evelon
Jaded (14-01-2017)
Old 13-01-2017, 08:32 PM   #13
jbvdb493
jbvdb493's Avatar
MC Status: 30910
Feedback loop.
This, and / or stacked delays
Old 13-01-2017, 09:42 PM   #14
D42K732202
D42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond repute
D42K732202's Avatar
My hell
MC Status: 8610
too late, too late ...
sent from another world
D42K732202 is offline   Thanks Reply With Quote
Old 14-01-2017, 02:52 AM   #15
Parricide
Parricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MC
Parricide's Avatar
MC Status: 18024419
i like to create an impulse response of both and use those to blend from one to the other by using sound As impulse on sound B. i also like using paulstretch to do extreme stuff. i use it on the tail of a reverb or on an impulse response or whatever works, mix it back in to the track as needed to create the transition.
some reverbs have a freeze function, which is nice, but loads of feedback on a reverb or delay will give you enough to work with.
reverse reverb on the following sound can help merge the two too, in combination with an impulse response from the first sound can often give nice results.
a combination of one or more of the above can work wonders
signature loading...
Parricide is offline   Thanks Reply With Quote
Old 14-01-2017, 04:59 PM   #16
chasedobson
Denver, CO
MC Status: 1540077
ctrl+C/ctrl+V
Thanks to chasedobson
I/O_Madness (26-01-2017)
Old 14-01-2017, 05:14 PM   #17
D42K732202
D42K732202's Avatar
My hell
MC Status: 8610
Originally Posted by chasedobson View Post
ctrl+C/ctrl+V
what about clicks and choppiness ? there are situations where it doesn't sound good
Old 14-01-2017, 05:22 PM   #18
Artificer
Ghostly
Artificer's Avatar
Southern Hell
MC Status: 35060
You gotta work on your Ctrl-C before you go Ctrl-Ving all over the place.
Old 14-01-2017, 06:10 PM   #19
D42K732202
D42K732202's Avatar
My hell
MC Status: 8610
then its not just ctrl c, v anymore
Old 14-01-2017, 07:36 PM   #20
chasedobson
Denver, CO
MC Status: 1540077
gotta find a good loop point, or cheat w some crossfades.
Sounds from VSTs do not follow full envelope (doesn't release after "sustain") samk44 Sound Design, Mixing, & Studio Techniques 12 15-05-2016 01:50 PM
Logic 9 - Random Sustain & Missing Notes on MIDI Out? Opus Science Workstation Center 1 11-04-2014 10:33 PM
[House/Deep house?] Sradc - Sustain sradc Listening Booth 3 21-11-2013 07:35 PM
[Altmodisch Sustain Piano] SCANDINAVIA Søvntrang Listening Booth 10 29-06-2012 12:17 PM
