How can I achieve this sound?
Old 04-01-2017, 04:53 AM   #1
wknightm
wknightm is currently spamming hard
Hey guys and gals,
General question, I'm rather new to this, but this is the type of sound I'm going for... can you recommend hardware (and software for Mac) which would make me best able to create the sound in this clip? I love this so much, it's the type of music I want to create for sure, I just don't know where to start, seems simple enough. Any particular synthesizer needed? Software? Etc...
Thanks ahead of time:
youtube---> watch?v=w08H_C_kTdA
wknightm is offline   Thanks Reply With Quote
Old 04-01-2017, 05:01 AM   #2
Artificer
Ghostly
Artificer's Avatar
Southern Hell
MC Status: 38360
Re: How can I achieve this sound?
Ambient music? Any DAW + softsynth + whatever reverbs and delays come with that DAW. You basically need a computer for hardware. Maybe some samples to stretch and effect if you want to get really crazy.
Artificer is online now   Thanks Reply With Quote
Old 04-01-2017, 07:12 AM   #3
wknightm
Thanks!!! I was about to buy/rent some equipment, but if something like FL12 will suffice, I'll just go with that.
Old 04-01-2017, 07:23 AM   #4
Artificer
Ghostly
Artificer's Avatar
Southern Hell
MC Status: 38360
Absolutely. Give it a shot.
I'll mention that you shouldn't be afraid to stack multiple reverbs and delays on top of one another to get those sounds. Those long, slow, plaintive sounds are usually the result of a single note or chord with tons of multi-stage echo allowed to ring out.
A good place to start would be something like this: (made for Ableton but applicable in pretty much any DAW)
Thanks to Artificer
Vault O))) (02-02-2017)
Old 04-01-2017, 07:49 PM   #5
Tubordinate
Tubordinate will become famous soon enough
Tubordinate's Avatar
Leicestershire , United Kingdom
yes these sounds can make a mix real interesting! cheers for the tutorial man
Tubordinate is offline   Thanks Reply With Quote
Old 04-01-2017, 08:08 PM   #6
Tubordinate
Old 02-02-2017, 05:28 AM   #7
wknightm
I may not be able to afford Ableton at nearly $1000 right now, are there any similar tutorials for relatively more inexpensive DAWs out there?
Thank you by the way, it's exactly what I am trying to achieve, that tutorial and the sound. Cheers.
Old 02-02-2017, 04:27 PM   #8
D42K732202
D42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond reputeD42K732202 has a reputation beyond repute
D42K732202's Avatar
My hell
MC Status: 8610
achieving sound is not hard, its much harder to not overachieve
sent from another world
D42K732202 is offline   Thanks Reply With Quote
Old 02-02-2017, 06:14 PM   #9
Vault O)))
Buttcase
Vault O)))'s Avatar
St. Augustine
MC Status: 54510
I don't know who would use stock reverb over IR's in drone, but he really soaked that shit. It's more fun to use granular samplers or just basic resampling to sustain tones, IMO
Vault O))) is online now   Thanks Reply With Quote
Old 02-02-2017, 07:15 PM   #10
White Noise
White Noise's Avatar
California
MC Status: 27160
A lot of the tutorials are done in ableton, this guy didn't say it, but you can do this stuff in any daw, you just have to "translate" it, if you will. If you have FL studio, your equivalent synth is going to be either Sytrus or 3xOsc and you can use Fruity Reeverb. You record audio with Edison and manipulate it in the play list. If you need help with the basics of FL studio, I'd look at SeamlessR's FL Basics on youtube.
Old 02-02-2017, 08:43 PM   #11
A.M
IDMf SupporterIDMf Artist
A.M's Avatar
MC Status: 198410
I'm going to recommend MuLab from [Only registered and activated users can see links. Click here to register]
..it's a fraction fo the cost of other DAWs out there, but every bit as good..and it runs on Mac, too.
I don't think you really need the added expense of hardware, other than a PC/Mac and some software to make ambient music..in fact, I KNOW you don't need to buy hardware, but if that's what you want, then realize up front that making ambient music can be as simple or as complex as you, the producer, want it to be.
You can make ambient music with two cans .. a bottle of water and a hand-held recorder..or you can spend as much as you like on a room-full of gear and still make the same sounds..the hardware route is usually one taken due to workflow and personal preferences..not really as a means to better ambient music.
Also, starting out, you don't need to spend a bundle on soft-synths either..there are more than enough free ones out there than will help you as you learn and improve your music production skill-set.
Try some of the H G Fortune vsts that can now be downloaded from [Only registered and activated users can see links. Click here to register]
for free, including some of his old Pro ones..all of them are now free. These synths were well and truly way ahead of their time when he introduced them..and the sound of some of them still hold their own today, when compared to other commercial offerings.
If you have some funds, then check out Art Pyrite from [Only registered and activated users can see links. Click here to register]
..the full version will set you back $60, but they do offer a stripped down free version, that although limited in the number of presets, doesn't come with any nags or intermittent noises during use. It's well worth grabbing the free version in any case, as it's a really good synth for making ambient stuff in general.
Reverb-wise, check out the free classic "[Only registered and activated users can see links. Click here to register]
", which is a good sounding basic reverb.
Also take a look at REFLEX free from [Only registered and activated users can see links. Click here to register]
I'm not 100% sure if you can actually run any or all of the above on a Mac, but there were/are the likes of [Only registered and activated users can see links. Click here to register]
or [Only registered and activated users can see links. Click here to register]
(you'll find a thread on it [Only registered and activated users can see links. Click here to register]
over on KVR).
And then there's [Only registered and activated users can see links. Click here to register]
which is a free download over on Sourceforge..
There's more than enough here to get you up and running, making ambient music in no time..unless, of course, you want to invest in hardware..but if I were you, I'd learn how to produce in this genre before I go splashing out of hardware, but it's your call.
Old 02-02-2017, 08:47 PM   #12
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8562380
As a hardware user Id say your best bet for forward thinking Ambient lies in software land.
Thanks to relic
A.M (02-02-2017)
How to achieve this vocal sound Börje Lindström Sound Design, Mixing, & Studio Techniques 4 19-06-2016 12:20 AM
please help me achieve this sound! NOOTHABEATS Sound Design, Mixing, & Studio Techniques 4 31-10-2015 01:03 AM
How to achieve a EDM sound, HELP PLEASE! Epoch House / Dubstep 6 07-12-2011 08:10 AM
PLEASE HELP! Trying to achieve a EDM sound Epoch Sound Design, Mixing, & Studio Techniques 1 07-12-2011 06:58 AM
How to achieve this bass sound ? electricpillow Sound Design, Mixing, & Studio Techniques 10 27-09-2011 03:55 PM
