Run the TR-8 AND your main soundcard in Ableton for Windows
Old 30-12-2016, 07:38 AM   #1
Deep Dose
Eternal Echoer
Deep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MCDeep Dose is a savage MC
MC Status: 17684405
Many know about this workaround for Rolands disappointing USB implementation with the TR-8, but many also do not, and are still griping with the compromise of choosing either 4 analog outs and their trusty soundcard or using the TR-8 as the soundcard to get individual inputs via USB.
I figured this information needs to be more widely available so why not post a thread.
You CAN use two audio devices at once in Ableton on both Mac and Windows, as long as both are capable of 96khz. On Mac it involves creating an aggregate device. On Windows you use Asio4all and activate both devices. I know asio4all isn't ideal, but if your computer is up to snuff it runs quite well.
1) With just your main soundcard connected, open a new Ableton project and the audio settings of your soundcard. Adjust the output sound to 96Khz then close the project.
2) Connect the TR-8 and allow any drivers etc to do their thing before opening Ableton up again. Select asio4all as your audio device in Ableton.
3) Open hardware setup in Ableton and in the asio4all settings activate both your main soundcard and the TR-8 as devices.
4) In asio4all settings open the dropdown for your main soundcard and activate its output. Open the dropdown for the TR-8 and activate all the desired inputs.
5) In Ableton audio settings open "Input Config" and activate all desired TR-8 inputs.
You are now able to monitor with your main soundcard while simultaneously running all of the TR-8 inputs into individual audio tracks in Ableton, and all in pristine 96Khz, which I found surprisingly ear pleasing. Actually changed my perception of the TR-8 a bit, incredibly punchy.
Its good to save a template project with this all set up. For example a drum group with a named audio track for each instrument in the order they appear on the TR-8.
I also like to use the TR-8 as the midi clock for Ableton as its far more stable, plus the play button on the TR-8 becomes your handy start and stop for ableton projects.
Running at 96khz and also using asio4all aren't ideal for CPU usage. It runs a bit hard while doing this, but if your workflow usually starts off with basic drums and some simple elements, you can get by and it runs quite smooth.
.....now keeping my fingers crossed for a firmware update from Roland that adds automation. Pipe dreams perhaps?
Deep Dose is offline   Thanks Reply With Quote
Thanks to Deep Dose
lolirl (30-12-2016)
Is it cheap to use an arp as main melody JayMSay Music Theory & Composition 60 29-07-2014 03:18 PM
I have my main riff, now what? SlvrDragon50 Music Theory & Composition 10 22-01-2013 11:19 PM
Why I Suggest FL Studio as your main DAW alex95 Workstation Center 61 04-05-2012 09:59 AM
Traktor Pro 2 Ableton Live 8 sync on Windows Chrome Noize Workstation Center 0 05-03-2012 07:55 PM
[Hip-Hop] Lions Main - MKoussa MKoussa Listening Booth 6 31-10-2011 09:15 PM
