bass distortion
Old 06-12-2016, 05:48 PM   #1
machinevos
machinevos is currently spamming hard
bass distortion
Hi i'm trying to recreate a sound from the nexus examples. Dit omdat je de instrumenten al weet van te
I really like the "drive/distortion" that has been put on the bass in this example
youtube slash watch?v=Qp0M8uE
Now i've tried every eq, drive, gain distortion out there and it just wont sound the same
Can anyone tell me by ear what kind of effect is on the bass.
Cause it sounds like distortion/overdrive/gain, but whithout it becoming "muddy".
I already a lot with the eq, but it seems as though there is another effect.
I dying to find out what this effect is because it sounds really cool.
machinevos is offline   Thanks Reply With Quote
Old 10-12-2016, 12:52 AM   #2
ViralSound
ViralSound will become famous soon enough
Re: bass distortion
i think you must use a sinoidal wave ,or directly find bass samples
ViralSound is offline   Thanks Reply With Quote
Old 14-12-2016, 02:05 AM   #3
envelope3
envelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond reputeenvelope3 has a reputation beyond repute
ottawa
MC Status: 9560
Re: bass distortion
If you want distorted bass without losing definition, run it in parallel like on an auxiliary send or double tracked carving out the eq to make room for the clean version to cut.
Sent from my SM-G925W8 using Tapatalk
envelope3 is online now   Thanks Reply With Quote
Thanks to envelope3
relic (17-03-2017)
Old 17-03-2017, 05:07 PM   #4
Harko City
Harko City is just really niceHarko City is just really niceHarko City is just really niceHarko City is just really nice
Harko City's Avatar
Indiana
MC Status: 360
Re: bass distortion
When I distort a bass, I like to take the bassier frequencis out with eq or a high pass and have an sine wave playing the bass frequency without distortion with the distorted bass. No muddiness with a sine.
Harko City is offline   Thanks Reply With Quote
Thanks to Harko City
relic (17-03-2017)
Old 24-03-2017, 09:57 PM   #5
aLiner
aLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond repute
aLiner's Avatar
Galway
MC Status: 2810
Re: bass distortion
guess what - The video is unavailable
aLiner is offline   Thanks Reply With Quote
Old 07-05-2017, 09:25 PM   #6
No Theory
No Theory will become famous soon enough
atlanta
Re: bass distortion
Ya I find it better to add distortion via an auxillary or return track, it is easy to apply distortion to just a certain percentage of the sound so the entire sound isn't just absolutely smashed to bits. Also using just a bit of distortion or saturation from several different channels can give the bass a nice texture
No Theory is offline   Thanks Reply With Quote
Old 09-05-2017, 09:45 PM   #7
TechnoVicious
TechnoVicious is currently spamming hard
Re: bass distortion
Normally just use heavy Saturation or if you're using Ableton, use Overdrive.
TechnoVicious is offline   Thanks Reply With Quote
Old 20-05-2017, 06:19 PM   #8
ATvrB
ATvrB is currently spamming hard
ATvrB's Avatar
Living in Denmark
Re: bass distortion
Very interesting! I'll try this.
When using ableton I really like to use the erosion effect on white noise and erode the higher lows
ATvrB is offline   Thanks Reply With Quote
Old 23-05-2017, 11:51 PM   #9
Somn
Somn is a name known to allSomn is a name known to allSomn is a name known to allSomn is a name known to allSomn is a name known to allSomn is a name known to all
Somn's Avatar
Stockholm
MC Status: 610
Re: bass distortion
I always run at least two basses.
One (almost) clean sine wave in the bottom and then another, distorted and high-passed copy on top of it. I occasionally add a bit of room to the high-passed one, depending on the mix.
Definitely not saying I am one of them, but this is standard practice from a lot of the best mixing engineers in electronic music, so not something I just made up.
Have a listen: on a lot of songs you can actually tell that the definition and clarity is sitting on top of the actual bass frequencies, as they are separated.
Somn is offline   Thanks Reply With Quote
Best distortion for industrial? thanatos Industrial / EBM / Power Electronics 67 28-12-2017 07:34 PM
Hardware distortion Automageddon Hardware and Gear 11 13-02-2016 09:10 PM
Mixing with FM distortion rokit9 Sound Design, Mixing, & Studio Techniques 15 13-03-2014 08:12 AM
How to get a more defined bass using other way than distortion/harmonics? smashingpoop The Studio 6 17-09-2012 06:10 PM
Need help getting rid of distortion in a bass... TSDREX The Studio 6 29-04-2012 10:54 PM
