Cakewalk SONAR is dropping numbered version releases - Page 3
Old 09-03-2015, 09:32 AM   #41
Roo Stercogburn
IDMf SupporterIDMf ArtistAdministrator
Roo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MC
Roo Stercogburn's Avatar
On horseback
MC Status: 42402499
Re: Cakewalk SONAR is dropping numbered version releases
I can't even load projects that previously used Melodyne into the latest version, it just errors on their tracks. Doesn't crash the DAW, but any audio clips with melodyne used as ARA just become white noise. This is a major problem for me as I've been heavily editing a lot of audio with Melodyne for a current project.
I did have a test of Vocal Sync. Its ok, nothing great. It may be helpful for polishing but I don't think its an earth shattering addition.
IDMf: Outside of porn, best cunts on the internet.
Roo Stercogburn is offline   Thanks Reply With Quote
Old 13-03-2015, 03:13 PM   #42
Rixtr
Rixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MCRixtr is a savage MC
Rixtr's Avatar
fuck you!
MC Status: 329126900
Yikes!
should have read this before upgrading....anyway,i went for the monthly bit and got platinum.supposedly i will own it after a year.my question would be,how do i reinstall without the actual software?unless i missed something,i didn't see anything about that.
still have my x3 installers....
Rixtr is offline   Thanks Reply With Quote
Old 13-03-2015, 03:23 PM   #43
Roo Stercogburn
On horseback
MC Status: 42402499
The installation doesn't affect X3, so that will still work fine. I've been using X3 solidly every day since installing SP without any issues. Some of the SP-bundled plugins work with X3, some complain they are only licensed for SP or later.
If you want to manually install, you can run the appropriate installer from the Command Centre download folder, which you can find by clicking on the gear icon.
Worth mentioning that anything installed by CC does not show up in Programs & Features, making it harder to keep track of what is installed on your PC, and of course complicating things should you wish to uninstall.
The quality of this upgrade is indefensible by anyone other than marketing people and blind fanbois.
Old 13-03-2015, 03:51 PM   #44
A.M
A.M's Avatar
MC Status: 198410
Given everything said here..would you guys suggest going for this if a person has never owned it before?
And how much space dose the install take up in total on your C Drive?
Old 13-03-2015, 04:18 PM   #45
Roo Stercogburn
On horseback
MC Status: 42402499
Sonar has always had some crazy-making quirks but I've used it for a few years now and it is basically a good product. Most of my issues in this thread are about the management of the latest version, rather than it as a DAW. Regarding size, not got access to my PC atm but bear in mind the number and size of plugins that go in your VSTPLUGINS folder(s) becomes a factor in calculating the required disk space.
Thanks to Roo Stercogburn
A.M (13-03-2015)
Old 13-03-2015, 05:05 PM   #46
A.M
A.M's Avatar
MC Status: 198410
Cheers, Ster..can ya get back to me on the space taken up..generally speaking..as I might check this out, given the monthly pan model they are offering.
Old 13-03-2015, 08:05 PM   #47
Rixtr
Rixtr's Avatar
fuck you!
@[Only registered and activated users can see links. Click here to register]
.i too have used sonar since x2,great product!as for disk space....i checked and it's hard for me to tell exactly for the new one,but when i get back on my machine,if roo doesn't
get back to you i will add it up!
Thanks to Rixtr
A.M (13-03-2015)
Old 13-03-2015, 08:45 PM   #48
Roo Stercogburn
On horseback
MC Status: 42402499
Here you go matey:
C:\Program Files\Common Files\VST3 28MB
C:\Program Files\Celemony 27MB
C:\Program Files (x86)\Cakewalk 10MB
C:\Program Files (x86)\Celemony 28MB
C:\ProgramData\Cakewalk 88MB
D:\MusicApps\Cakewalk 54GB (note, GB here)
D:\MusicApps\Cakewalk Content 11GB (...and here)
D:\MusicApps\Cakewalk Projects 702 MB
Of the above, the D:\MusicApps\Cakewalk\SONAR X3 Producer only takes up about 83 MB and D:\MusicApps\Cakewalk\SONAR Platinum is around 168MB, the rest are plugins and stuff that comes with Sonar and is shared between the applications. My folders might be slightly larger because I have several versions of Sonar plugs and toys in my installation but I don't think it will be a massive amount of difference in size for a fresh installation.
I have a 128GB SSD as my system drive, so you can see that if I had to put around 66GB of Cakewalk stuff on my C: drive it would cause me some system issues. I'll be upgrading later in the year but you get a bit of insight into why I'm seething at the dumbfuck developers that thought it was ok to shit on someone's C: drive.
Note also that I have the Command Center downloads in D:\MusicApps\Cakewalk\Command Center\Downloads which accounts for about 10GB of that 54GB.
Old 13-03-2015, 10:51 PM   #49
A.M
A.M's Avatar
MC Status: 198410
Umm..my main HD is the same as yours. Don't think I'll be getting it then..not just yet..not until I, too, get a bigger drive to hold that monster!
Old 13-03-2015, 11:09 PM   #50
Rixtr
Rixtr's Avatar
fuck you!
Got pretty much the same figure a little lower but i have a tb hdd.so i really don't worry.
meh.
Thanks to Rixtr
A.M (13-03-2015)
Old 13-03-2015, 11:20 PM   #51
Roo Stercogburn
On horseback
MC Status: 42402499
Current system has 6TB (7200rpm drives) across several drives, not including system drive, not including backup storage and other external devices. Storage not an issue for me. Just idiot devs
Old 13-03-2015, 11:23 PM   #52
Rixtr
Rixtr's Avatar
fuck you!
BLAH BLAH BLAH...
I HAVE 6TB nyah nyah...
gotta figure out raid.......
Old 13-03-2015, 11:59 PM   #53
Roo Stercogburn
On horseback
MC Status: 42402499
Originally Posted by Rixtr View Post
BLAH BLAH BLAH...
Got RAID. Whole lotta people don't realise one of the mahoosive caveats of it, hence my chuckle earlier in this thread.
Old 14-03-2015, 12:06 AM   #54
Rixtr
Rixtr's Avatar
fuck you!
Heh yeah,i have a massive case w/6 pullout bays.
just haven't had the $ to get 4 more seagate barracudas.
they are cheap $60.00 but i have to include the one i have which is on its last legs.
still not sure about ssd as the main though.not to mention the sonar platinum install.
Old 14-03-2015, 01:37 AM   #55
Roo Stercogburn
On horseback
MC Status: 42402499
When you install a RAID solution you're advised to install HDDs by different manufacturers or at the very least HDDs from different production batches. The reason is that similar HDDS will have the same Mean Time Before Failure, so if you build from the same source, your system is likely to lose all its hard drives around the same time.
When you look inside prebuild machines, a lot of them have HDDs installed in sequence as they came off the production line.
So your HDDs are likely to fail together. Not guaranteed, but statistically possible.
So when people scoff and quote "RAID" at me, I smile and wonder if they know their stuff or have simply drank from their supplier's Koolaid.
So for any random Cakewalk forum users browsing here on the back of our short-lived friend that came out to hunt me... I'm not infallible but my tech fu is strong:
Command Center is a bag of shite.
Seriously.
Old 14-03-2015, 01:49 AM   #56
Roo Stercogburn
On horseback
MC Status: 42402499
Also, feel a bit humbled at the support guys. Much appreciated. Maybe I don't say that enough, but I really do appreciate.
A.M (14-03-2015)
Old 14-03-2015, 01:56 AM   #57
A.M
A.M's Avatar
MC Status: 198410
The answer's still NO!
Thanks to A.M
Roo Stercogburn (14-03-2015)
Old 14-03-2015, 03:00 AM   #58
candlesayshi
Imperfect
candlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MCcandlesayshi is a savage MC
candlesayshi's Avatar
Chicago
MC Status: 39281549
Seriously.
But I understand that you can still download the separate installers from your account page on the website just like before, right?
candlesayshi is offline   Thanks Reply With Quote
Old 14-03-2015, 10:17 AM   #59
Spiritos
Ghostly
Spiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond reputeSpiritos has a reputation beyond repute
Spiritos's Avatar
Amsterdam
MC Status: 7010
What about the R-Mix and Pro-Channel and some other stuff that only came with X2 (and were a hassle to use in X3?) Are they part of the new Sonar versions?
Win8.1 64x/Sonar X3/Live 9/Steinberg UR44/Roland HP 235/Edirol PCR-800/Eastman AC 222/Washburn D12/Behringer BCF2000 & BCF2000/Korg Nanopad 2/Focusrite VRM Box/AT2020/2xB5/Sennheiser E 825s/Beyerdynamic DT-990 Pro 250/Tannoy 502
Spiritos is offline   Thanks Reply With Quote
Old 14-03-2015, 06:29 PM   #60
Roo Stercogburn
On horseback
MC Status: 42402499
<checking> ...
Some are on the list, some aren't. I have more install-files in the download folder than products on the My Products webpage, even when counting stuff I bought separately (like Z3ta+2, previous versions of Sonar, etc).
Aside from the Braintree update, there are 19 executables in the CC download folder and 2 .RTF files which are placeholders/instructions on how to download Melodyne and Addictive Drums 2 from their respective websites.
I'll try and remember to take a peep next time I'm in there.
Spiritos (14-03-2015)
Cakewalk Sonar X3? Roo Stercogburn Workstation Center 65 09-01-2014 05:08 PM
Cakewalk announces SONAR X2!!! candlesayshi Workstation Center 25 15-03-2013 10:53 PM
Getting Cakewalk Z3TA +2 to work in Ableton gammarang Workstation Center 6 03-11-2012 08:59 PM
Cakewalk Sonar X1: Cut'n' Paste Automation Roo Stercogburn Workstation Center 9 02-11-2012 08:58 PM
[Breaks/Techno] Online Mixing Service version Vs. My version modescmoesc Listening Booth 8 07-12-2011 11:31 PM
