How to overcome a "block"? - Page 3
Music Theory & Composition Questions & comments about composition, arrangement, and music theory. Music rules and how to follow or break them.
Old 21-03-2017, 11:45 AM   #41
Nystagmus
Nystagmus's Avatar
Planet Earth; 2017 AD.
MC Status: 65460
Resist
Like much of everything else, avoid and actively resist all fearmongering and conformity to insanity. Brains work better this way.
Old 21-03-2017, 03:41 PM   #42
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8548930
Re: How to overcome a "block"?
Two ideas I fully support:
1. Travel
2. Sampling (in generally, though horror movies have a lot of good fodder, probably sci fi too)
As for the travel thing, just if people think they have to go far from home, I don't think that is necessary. While I agree a bit of "culture shock" is the best, even getting out of town to the "big city" or the "country"...just a change of scenery can be refreshing. Some people seem to like to take some gear with them, personally I subscribe more to the experience and absorb theory...go have the experiences and write about them later, but whatever floats yer boat!
Old 21-03-2017, 04:58 PM   #43
Vault O)))
Vault O)))'s Avatar
MC Status: 44560
I figured out the code
Aside from knowing your ABACABB's, the real trick is to just mash A, B and C, and hit start when you're above the line. The block will be overcome, and then you can advance to the next level.
Old 21-03-2017, 06:31 PM   #44
iDoG
iDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MCiDoG is a savage MC
iDoG's Avatar
Chicago
MC Status: 17760
the same applies to coming up with song structure. at least it works for me.
iDoG is offline   Thanks Reply With Quote
Old 21-03-2017, 07:10 PM   #45
PROton42
PROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MCPROton42 is a savage MC
PROton42's Avatar
MC Status: 36100
Is it bad that the very first comment I had on that tutorial was "This is how Genesis wrote Abacab."
PROton42 is offline   Thanks Reply With Quote
Thanks to PROton42
Vault O))) (21-03-2017)
Old 28-03-2017, 05:20 PM   #46
ColinMolton
ColinMolton will become famous soon enough
If you're blocked, you might just be empty. Try taking a break and trying some random stuff (not necessarily related to the project) for a while, then going back and trying again
ColinMolton is offline   Thanks Reply With Quote
Thanks to ColinMolton
hellscion (29-03-2017)
Old 29-03-2017, 05:16 PM   #47
NotApplicable
Microknight
NotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond reputeNotApplicable has a reputation beyond repute
NotApplicable's Avatar
MA
MC Status: 2860
I like to listen to non-edm/electronic music when I am not mixing or creating tracks. It clears the mind and helps to focus on the electronic work at hand.
NotApplicable is offline   Thanks Reply With Quote
Old 09-04-2017, 07:48 AM   #48
ziino
ziino is currently spamming hard
walk in nature, listen to music that you wouldnt usually listen to.
ziino is offline   Thanks Reply With Quote
Old 11-04-2017, 01:42 PM   #49
Muse-ic
Wanderer
Muse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MC
Muse-ic's Avatar
MC Status: 6963583
The best way to overcome a block is think about how you would overcome a block in another situation. If you are walking down the street and something is in your way, you need to move or find another path.
Basically you need to do something different, or try another path.
Sometimes it just means breaking through what is blocking your way by keeping at it. I think everything worthwhile takes grit when you get past the high of a new idea. So working through it and finding new avenues are the best way to keep along your journey.
Put one foot in front of the other and keep going!
Muse-ic is offline   Thanks Reply With Quote
Old 16-04-2017, 07:00 PM   #50
Stressshot
Stressshot will become famous soon enough
Helsinki
Had a sick block couple days ago which still haunts me a bit. Thoughts of ending making music. Made a little bit of a music today just now. Feels okay. Feels fresh. Kept telling me its just this resistance
Here is my secret weapon : War of Art pdf. You can just google it.
Stressshot is offline   Thanks Reply With Quote
Old 20-04-2017, 04:09 AM   #51
DreyDay
DreyDay is currently spamming hard
Awesome book, the War of Art. Should be on the list of anybody who produces music. I had a long writer's block, and after studying some music theory I was able to overcome it. What I did was play around on the keyboard with various scales and keys, and combining matching chords that correspond with each key. I was able to come up with some cohesive music at that point.
Do you know scales well? Try playing around with combining chords together and see what you can come up with.
DreyDay is offline   Thanks Reply With Quote
Currently Listening To: Smashing Pumpkins - Pale Horse
Old 09-05-2017, 01:26 PM   #52
DRR
DRR is a splendid one to beholdDRR is a splendid one to beholdDRR is a splendid one to beholdDRR is a splendid one to beholdDRR is a splendid one to beholdDRR is a splendid one to behold
DRR's Avatar
Derbyshire
MC Status: 660
While I'm listening to 'incidental' music (I mean the kind of music playing in the background in TV adverts, TV progs, film themes etc) my mind often races ahead and composes the music as it should have been, rather than how it actually is. The secret is then to get the idea down on paper, recorded etc as soon as possibe, because 1 minute later I know I will have forgotten it.
DRR is offline   Thanks Reply With Quote
Old 09-05-2017, 02:56 PM   #53
NotApplicable
Microknight
MA
MC Status: 2860
I haven't produced anything in about a month. I just sat down to try and flesh out the track I'm working on and everything seems wrong.
I don't have that fire anymore and I need to get it back.
Old 26-05-2017, 07:22 PM   #54
Kyrpto
Kyrpto is a name known to allKyrpto is a name known to allKyrpto is a name known to allKyrpto is a name known to allKyrpto is a name known to allKyrpto is a name known to all
MC Status: 560
Trying working on another song or start a new one. If that doesn't work take a break. Go outside, watch some TV or whatever it takes.
Kyrpto is offline   Thanks Reply With Quote
Old 26-05-2017, 07:38 PM   #55
DRR
DRR's Avatar
Derbyshire
MC Status: 660
Just a few suggestions
Could it be the song is going nowhere, so start again? (I know someone else suggested this)
Do you start from your own standard template (I often start with my own standard percussion line)? If so, then start fresh.
Do you start with the programming or analogue instrument? Either way try starting with the other.
Just try it a different way.
And definitely read War of Art
Old 26-05-2017, 10:09 PM   #56
Mario D
Sample Destroyer
Mario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond repute
Mario D's Avatar
Croatia
MC Status: 2960
Listen to this guy, this guy has no blocks in his life. He is making new song every 2 days.
Mario D is offline   Thanks Reply With Quote
Old 27-05-2017, 01:15 AM   #57
Kyrpto
MC Status: 560
ROFL! Unfortunately I'm limited to posting only 1 per week because i have under 300 posts. Most of it is not viable anyways.
Thanks to Kyrpto
Mario D (27-05-2017)
Old 27-05-2017, 07:38 AM   #58
Muse-ic
Wanderer
Muse-ic's Avatar
MC Status: 6963583
An apple a day; keeps the doctor away
Old 27-05-2017, 07:10 PM   #59
Vault O)))
Vault O)))'s Avatar
MC Status: 44560
I dunno, I usually stick to cooked foods when I'm feeling blocked. Different strokes
Old 07-06-2017, 10:19 AM   #60
Muse-ic
Wanderer
Muse-ic's Avatar
MC Status: 6963583
I saw this today on a musician site and thought it applied, "The art of practicing is finding a process for repetition without boredom".
[Techno] COINS "Care of cell block 101100" Coins Listening Booth 7 13-05-2013 03:15 PM
A simple walk through the local mall tells the word "musician" = "mythical SHIBA INU" jimmusician Music Scene Chat 142 05-08-2012 03:14 AM
2 new tracks! "Kick Snare Bass" & "Midwest Anthem" [Looking for creative criticism!] ohaimishae Listening Booth 2 17-10-2011 06:46 PM
