Side Chain Compression. Yay! - Page 2
Old 30-10-2015, 01:02 AM   #21
jbvdb493
jbvdb493's Avatar
MC Status: 32060
Re: Side Chain Compression. Yay!
Yeah man i wouldn't use multiple compressors in series for a side chain pumping effect
Someone more knowledgable than I could correct me if I am wrong but that doesn't seem the place to use compressors in series
You can for sure use serial compression for other applications tho for a more subtle effect but I think in the case of getting a side chain style pump going it's the opposite of what you want!
Old 30-10-2015, 02:08 AM   #22
Bergnermd
Sample Destroyer
Bergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud ofBergnermd has much to be proud of
Bergnermd's Avatar
Wisconsin
MC Status: 1460
It seems to be working for me, the reason I do that is to get a ton of gain reduction for a tiny amount of signal that goes over the threshold
The reason I feel the need to do this is because I really don't trust ableton's native equipment to a fairly good job in obtaining the sound I am searching for
And I was just thinking that some one/ company would design a better compressor that handles ducking somewhat better
Bergnermd is offline   Thanks Reply With Quote
Old 30-10-2015, 02:12 AM   #23
Bergnermd
Sample Destroyer
Bergnermd's Avatar
Wisconsin
MC Status: 1460
Originally Posted by liquid_air View Post
Why do you not use one compressor and crank up the ratio?
Seems that you successively compress your peaks and by the third time you probably are looking at a hard clipper effect, which will distort the compressed signal. Listen to your side gain out and see if that's going on.
Just adjust threshold and ratio until you get enough reduction.
I do not get any distortion because each compressor is only working to compress a small amount of gain for a larger total gain.
When I crank up the ratio on just one I don't get the amount of gain reduction I am looking for (comparing recorded audio to samples from packs I have bought that have ducking effect)
I don't trust ableton's native audio tools because each one I work with seems to have some sort of undesired effect
Old 30-10-2015, 03:20 AM   #24
liquid_air
liquid_air's Avatar
Corny
MC Status: 61960
FabFilter Pro MB does a fine job.
Also Ozone's compressor.
Are you sending the side gain signal with enough gain?
Old 30-10-2015, 09:13 AM   #25
Evelon
Evelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MCEvelon is a savage MC
Evelon's Avatar
MC Status: 214390098
^This!
I think this might be your issue, Bergnermd. Also, use short and transient types of ghost "kick" in order to really play with the compressor sustain.
If you use your kick (and not a ghost kick) you can highpass + saturate the kick before going to key/side input of your compressor.
Evelon is offline   Thanks Reply With Quote
Old 31-10-2015, 04:16 PM   #26
professurreal
professurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MCprofessurreal is a savage MC
professurreal's Avatar
at the end of the tunnel
MC Status: 59510
Honestly, one compressor is enough and if you don't manage to get the right sound with the Ableton compressor I think you're doing something wrong as the stock compressors work just fine.
Try some of the other suggestions people made such as ghost kick for sidechain as that allows you to modify all kinds of parameters such as note length without it affecting your actual kick drum.
professurreal is offline   Thanks Reply With Quote
Thanks to professurreal
jbvdb493 (31-10-2015)
Best side-chain compression software? Articutt Sound Design, Mixing, & Studio Techniques 38 03-05-2015 01:20 PM
Side-chain compressing offbeat bass pointless? JayMSay The Studio 19 23-08-2014 01:37 AM
How to side chain in Maschine 2.0 Flux302 Tutorials Section 0 30-10-2013 02:55 AM
Side-Chain Woes Friend Request Sound Design, Mixing, & Studio Techniques 2 02-02-2013 05:05 PM
compressor in a compressors side chain. bliprock Sound Design, Mixing, & Studio Techniques 7 23-11-2012 08:02 PM
