"Can't polish a turd" myth - Page 2
Old 11-08-2015, 10:34 PM   #21
RFJ
IDMf ArtistModerator
RFJ's Avatar
I live in California.
MC Status: 199645668
Re: "Can't polish a turd" myth
...and glitchhopforum?
Probably.
Old 11-08-2015, 11:14 PM   #22
agent
Deep Underground
agent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MCagent is a savage MC
agent's Avatar
SEATTLE
MC Status: 526870
Are we still discussing this?
If so... I have my own quote "there is no right way, just the right sound"
That being said...
Having much experience in graphic design, the idea was always to use the graphics with the best dpi (dots per inch) later pixles per inch. The more the better quality the original, the better quality the original, the more that could be edited , enlarged and so on.. the more you could save that file electronically as well.
Case in point, take a jpeg in any modern graphic software, photoshop etc... save it as a jpeg and at a low quality, do it again and again and again.. after maybe 5 times or so depending, the picture will be all fucked up quality wise. Pixalated and blurry.
I feel the same applies to recorded audio, you record a snare hit at a lesser quality bit depth, then save it again and again and edit and do this and that.. and it degrades the sound/file/recording.
Now does this mean you shouldn't do that? Again, there is no right way, just the right sound.
In fact, I purposely record/export at shitty bit depths to get glitchy shitty sounds, such as from a crappy old sampler or to get artifacts and coloration to my sounds for that old school lo-fi sound.
Experimentation and understanding your tools is key
agent is offline   Thanks Reply With Quote
Thanks to agent
relic (12-08-2015)
Old 12-08-2015, 01:37 AM   #23
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6906309
Originally Posted by Br/ainfu+ked View Post
just google the artist that used elephant dung
i don't even
Erm maybe I'm missing something. All I could find was a painter who used elephant dung as pigment in a painting. That's not an example of polishing a turd... Mainly because it's an example of someone applying pigment to a canvas AKA painting. I'd wager if you looked in any Renaissance museum you'd find a heap of paintings that use shit as pigment.
The saddest part is that every article trivialises the painting by leading with "painting made of elephant dung". The painting only holds a novelty value because it's mixed media with poo. I mean, even you reduced the whole work down to a piece of shit just to prove a point. Which it doesn't because it's not a piece of shit... And besides, even if it was, I'm pretty sure you can't polish an oil painting...
Thanks to Jaded
Br/ainfu+ked (12-08-2015)
Old 12-08-2015, 01:47 AM   #24
Andantonius
Sample Destroyer
Andantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond reputeAndantonius has a reputation beyond repute
Andantonius's Avatar
MC Status: 7610
You can varnish them though. Helps to keep them preserved. You have to wait like 15 years or some bullshit for the paint to actually fully dry before you do it though.
Andantonius is offline   Thanks Reply With Quote
Old 12-08-2015, 02:56 AM   #25
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6906309
^ Okay. So let's get this straight then. According to you and me, the only way you could feasibly polish a turd is if you varnish it first. But you'd have to wait fifteen years for that shit to dry before it's safe to do so.
Fifteen years seems like a long time to have to wait just to polish a turd
Old 12-08-2015, 03:45 AM   #26
Nystagmus
Nystagmus's Avatar
Planet Earth; 2017 AD.
MC Status: 65460
</THREAD>, please now!
Thanks to Nystagmus
Jaded (12-08-2015)
Old 12-08-2015, 04:03 AM   #27
Oatbag
Oatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MCOatbag is a savage MC
Oatbag's Avatar
Best Coast
MC Status: 110000
Pfff... no problem guys. You just need some of this and some elbow grease!
Oatbag is offline   Thanks Reply With Quote
Old 12-08-2015, 09:56 AM   #28
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6906309
^ You mean all of this fucking time...
Old 12-08-2015, 11:07 AM   #29
Muse-ic
Wanderer
Muse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MCMuse-ic is a savage MC
Muse-ic's Avatar
MC Status: 6963183
Wow, @[Only registered and activated users can see links. Click here to register]
this was the jaded of all posts. LOL, you really went all out to point out the finer points of....
Muse-ic is offline   Thanks Reply With Quote
Old 12-08-2015, 12:25 PM   #30
Br/ainfu+ked
Br/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MCBr/ainfu+ked is a savage MC
Br/ainfu+ked's Avatar
blah
MC Status: 45964898
Actually I wasn't even trying to make a point.
I don't know dude....:shitstorm:
what is this thread even about. Artistic expression?
I thought someone else already made the point a few posts back.
Br/ainfu+ked is offline   Thanks Reply With Quote
Thanks to Br/ainfu+ked
Jaded (13-08-2015)
Old 12-08-2015, 01:09 PM   #31
Roo Stercogburn
IDMf SupporterIDMf ArtistAdministrator
Roo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MCRoo Stercogburn is a savage MC
Roo Stercogburn's Avatar
On horseback
MC Status: 42398649
Imma just subbing to thread.
IDMf: Outside of porn, best cunts on the internet.
Roo Stercogburn is offline   Thanks Reply With Quote
Old 12-08-2015, 02:55 PM   #32
fidelium
fidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MCfidelium is a savage MC
fidelium's Avatar
\(_o)/
MC Status: 2147483647
so like we all realize that even if you polish a turd it's still a turd right. like if you polish one are you gonna put it between some bread with some mayo and eat it? shit I know I would, I'd wash it down with a nice cool Budweiser
fidelium is offline   Thanks Reply With Quote
Old 12-08-2015, 04:01 PM   #33
relic
relic's Avatar
The AK Rowdy Rowdy
MC Status: 8560880
you sir, are a fucking savage :snob:
Old 12-08-2015, 06:47 PM   #34
Numerical
Numerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MCNumerical is a savage MC
Numerical's Avatar
Austin
MC Status: 45947281
Try our delicious oven-roasted chipotle turdburgers
brumski
Numerical is offline   Thanks Reply With Quote
Old 12-08-2015, 06:48 PM   #35
Numerical
Numerical's Avatar
Austin
MC Status: 45947281
I love these threads I really do
brumski
Old 12-08-2015, 06:51 PM   #36
Kvlt O)))
Is a retard
Kvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MC
MC Status: 153560
This riddle is easy, if you follow my turd-zen. If it's a turd, don't try to hide the turd within. Just accept the turd for what it is. Maybe even smear it around a little. Have fun with the turd, and when you show it to people, let them know it really is a turd. If they're expecting chocolate cake, they will definitely be able to tell the difference.
Kvlt O))) is offline   Thanks Reply With Quote
Thanks to Kvlt O)))
relic (13-08-2015)
Old 12-08-2015, 06:51 PM   #37
oly
oly is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MColy is a savage MC
oly's Avatar
socialism twitter
MC Status: 471672651
It doesn't mean you literally can't.
It means that you can only do what you can do with what you have.
or GIGO or something idfk give me food you pleb
oly is offline   Thanks Reply With Quote
Old 12-08-2015, 06:53 PM   #38
oly
oly's Avatar
socialism twitter
Thanks to oly
Kvlt O))) (12-08-2015)
Old 12-08-2015, 07:13 PM   #39
Crude_beats
Banned
Crude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MCCrude_beats is a savage MC
Rocking my boat across the seven seas
MC Status: 115728
Originally Posted by Dimension View Post
This is something I have been wondering for quite some time now, the "don't polish the turd myth"...
As a person who picks up pieces of garbage and things that look abandoned to make them into a family of similar pieces to become something beautiful, I have never really agreed with this way of thinking but maybe theres something important im missing (which is why im posting this thread). Anyway, I always find myself looking at parts that I didn't mean to record, usually subby bumps and clicks and slides and using those and it makes me think, why not polish a turd when you can just layer different parts of the waveform (transients, body's, tail's, etc) and process them individually to add/subtract attractive/unattractive frequencies? Is this type of mentality based on getting things finished in a hurry and that's why it's better not to spend too much time on these kinds of things?
What do you think?
Thank you
D
It really depends on the definition of turd and what you wanna achieve. You wanna make opera? Make sure the vocal is near flawless. Wanna make the kick sound better, then there is lots you can do.
You can make most things sound good though with enough processing unless its a bad performance even with a half assed performance you can cut and paste and layer different takes
And most samples wont work out the box in the tune you work on, so everything needs a little polish
I find making layers of anything just makes it always better. Just keep layering and resampling and test shit. The norm being having most layers on the chorus.
Crude_beats is offline   Thanks Reply With Quote
Old 13-08-2015, 07:33 AM   #40
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6906309
I don't know either man. I kinda feel like things are heading towards talking about our feels...
Thanks to Jaded
Br/ainfu+ked (13-08-2015)
Mixing on headphones myth Dhji The Studio 30 15-08-2015 08:30 PM
[Jazz/Slow Breaks] Phyla Zen - Turd Burglar phylazen Listening Booth 5 14-08-2013 10:03 PM
Terrific or Turd? alphx Music Theory & Composition 10 28-11-2012 10:39 PM
Myth of PROMeTHeUS oly Ambient / Downtempo 0 21-07-2012 01:25 AM
The pluses and minuses of being a lowlife, alcoholic, bigoted turd Knobeye The Side Room 30 02-02-2012 12:45 PM
