Do you have a template setup for your DAW - Page 5
Old 14-02-2017, 04:09 AM   #81
White Noise
White Noise's Avatar
California
MC Status: 23260
Re: Do you have a template setup for your DAW
I have four templates, all of them exist only for speeding along the gainstaging and monitoring process. All of them have a spectrum analyzer and pre/post gain db meters, a disabled limiter for WIP rendering, and a dynamic range/loudness meter on the master. The first just has the faders on the first 30 channels turned down to -30 db with some gain as an insert on the master to compensate. The second is the same as the first, but with a console emulation set up on each channel and tied into the master properly for that plugin. The third and fourth are similar to the first two, but the gain on the master channel uses a bitshift gain that is more transparent, but less precise.
Also, check this out. Updated 1-19-18.
https://www.facebook.com/JP4onthefloor/
Thanks to White Noise
Daggit (29-09-2017)
Old 14-02-2017, 02:43 PM   #82
Neuralsphere
Sample Destroyer
Neuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond reputeNeuralsphere has a reputation beyond repute
Neuralsphere's Avatar
Midlands
MC Status: 9560
I used to have templates... helps if you forget things and saves time, but could limit your creative workflow and leaves less room for experimentation - It is a double edged blade but the most fun part of production is mixing it up... excuse the pun.
Neuralsphere is offline   Thanks Reply With Quote
Old 02-06-2017, 09:40 PM   #83
maxadax
maxadax will become famous soon enough
maxadax's Avatar
Buckingham Palace
The only thing that I really changed about my default Ableton Live set is the reverb. I changed from the default one to the Valhalla Plate reverb.
I once tried to set default sidechain channels and other things but I found that my production technique was too spontaneous and I would just end up deleting all these channels pretty early on.
maxadax is offline   Thanks Reply With Quote
Old 08-06-2017, 11:53 AM   #84
Parricide
Parricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MCParricide is a savage MC
Parricide's Avatar
MC Status: 18024419
i know this is an old ass thread but i probably missed it.
i use a few templates, one for each of the potential jobs at hand.
they do not contain routing, sends, inserts e.t.c. (apart from on the master) though, since this changes every time for me. i use them to get my layout and settings where i want them.
the inserts on the master are utilities such as frequency analysers, meters e.t.c.
signature loading...
Parricide is offline   Thanks Reply With Quote
Old 08-06-2017, 02:55 PM   #85
metalzone2000
metalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MCmetalzone2000 is a savage MC
metalzone2000's Avatar
Houston, Texas
MC Status: 57924
For Renoise yes. Everything else no.
A random patch I did with Bazille, Gverb, AM Pitchshifter, Autotalent, and 24 random LFO's in Renoise.
metalzone2000 is offline   Thanks Reply With Quote
Old 29-09-2017, 03:42 PM   #86
Daggit
Master of the LFO
Daggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond reputeDaggit has a reputation beyond repute
Daggit's Avatar
"Let beauty loose!" --Nitzer Ebb
MC Status: 8660
I wish I had some better templates.
I am realising again and again that anything that emulates an SSL console in use is helpful.
For a long time I used a template of plugins on my master, but lately I moved that to a group so I can leave a few items out of it. But that's very similar to doing DSP grouping on a console.
And the thing is, in sound engineering school they taught us how the SSL consoles were so advanced and people made so many hits on them. The only thing different about them besides just being good quality components was that there was a compressor/limiter in EACH channel! That may not sound amazing now, with computers, but back then that was astounding.
So now, what I'm going to do is create a track template where every track has everything it would need in a pro console plus some nice extras. I'm thinking like my best VST EQs, my best spectrum analysers, and my best limiter... all on each channel.
And then a few group channels designated for mono / bass LFE, and a different group buss for stereo front.
It's interesting to be essentially going back to classical mixing, almost. I'm kind of excited about this because I know it will work.
{novel, fresh, different, recent, modern, unexampled}
Daggit is offline   Thanks Reply With Quote
Project Template - DUBSTEP Red Stalker Sound Design, Mixing, & Studio Techniques 37 24-09-2014 12:23 AM
Live 9 Template for Producing sondericker The Studio 10 01-05-2014 04:45 AM
Whats your personal send FX template henryspencer The Studio 14 07-02-2013 12:49 PM
Free Ableton template djsam Sound Design, Mixing, & Studio Techniques 0 14-12-2012 10:11 AM
Template Ideas? Truesdale Workstation Center 0 13-12-2011 12:24 PM
