Do you have a template setup for your DAW - Page 4
Old 01-09-2015, 02:41 AM   #61
Kvlt O)))
Is a retard
Kvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MCKvlt O))) is a savage MC
MC Status: 153560
Re: Do you have a template setup for your DAW
We should have a template exchange on here
Kvlt O))) is offline   Thanks Reply With Quote
Old 01-09-2015, 07:56 AM   #62
Nystagmus
Nystagmus's Avatar
Planet Earth; 2017 AD.
MC Status: 65460
In Reaper, i save the layouts for different views and also save VSTi presets in Reaper format.
Old 24-09-2015, 06:28 AM   #63
vashima
vashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MCvashima is a savage MC
vashima's Avatar
Pocatello, Idaho
MC Status: 13560
That would be sweet. I have spent a decent amount of time making templates for pro tools; routing Native Instruments Battery to individual channels with busses, side compression set on all the appropriate channels etc. I would hate to set this up every time I was feeling creative. I would love to play around on other peoples templates too. How do we go about this?
vashima is offline   Thanks Reply With Quote
Old 25-09-2015, 07:52 AM   #64
Nystagmus
Nystagmus's Avatar
MC Status: 65460
Unfortunately, I wouldn't be able to share some of my VST presets because I like to rename my VST .DLL's to names that are more logical. Names like Fre(a)kascope-X11_2 modular.dll are ridiculous to me, so I just rename it to something like fScope.dll
But I would still try to help sharing templates.
Old 25-09-2015, 10:31 AM   #65
ms_
ms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MCms_ is a savage MC
ms_'s Avatar
MC Status: 123160
do you also rename "Reaktor5.dll" to "Reactor.dll" and "Kontakt5.dll" to "Contact.dll"?
ms_ is offline   Thanks Reply With Quote
Old 26-09-2015, 09:32 PM   #66
Nystagmus
Nystagmus's Avatar
MC Status: 65460
Icon12 Re: Do you have a template setup for your DAW
Actually, sometimes i do. Although I don't rename payware installs as those can be broken. I mostly use freeware though and if it's version 1 or 2 or whatever of vaporware, I know there aren't going to be any other versions so I just install whatever version works and get rid of the number.
I know this is slightly OCD of me, but for some reason when I'm glancing at my archives the numbers confuse me slightly. When it's just words, I'm not as confused.
Luckily, Reaper lets you rename the VST(i)'s from within the interface so I've been doing more of that instead of renaming the .DLL's So instead of TAL-Reverb 2 (TAL-Togu Audio Line). It just says TAL-Reverb (Togu Audio Line). Since I only use one of those, I'm not confused by the versioning.
I know yeah, I'm a little bit retarded about this, but it's just how my mind works.
But I still rename the DLL's as part of archiving. Typically, I delete everything in the archive except for the DLL and the manual and resave it as a 7zip instead of a zip. It makes it a lot easier during re-installs to not have tons of garbage files. And I give the archive name a name I will remember, instead of something obscure.
Also, in my VST folder, I put each VST into it's own folder which also makes it a lot neater and easier to read. And when .SEM and tmp files get created, they aren't poluting the main folder.
I know this is anal, but I am actually less anal about this stuff than I used to be.
...Actually, some templates for Reaper still might work, because Reaper uses the internal VST file name instead of the hard drive name I think. So maybe I could contribute some templates.
Thanks to Nystagmus
Schnork (30-09-2015)
Old 30-09-2015, 08:01 AM   #67
Schnork
Schnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MCSchnork is a savage MC
Schnork's Avatar
MC Status: 19910
I also have seperate folders for 32 bit/64bit (dll), program, content/library and ofc I don't allow a plugin to install somewhere into documents/program data or what ever else on C: - Has to be nice and clean
I'm also trying to keep my synth patches and samples somehow sorted logically - Which might seem easy, but imagine having synth patches from more a decade^^
Maybe I should delete all those useless factory presets as well as those I've downloaded for whatever reason. Don't use presets anyway. Dunno, makes me feel superstar dj^^
Sample folders simly is a mess, but I don't work with samples anmore anyway....
Ofc I have templates for my DAW.
Schnork is offline   Thanks Reply With Quote
Old 30-09-2015, 06:22 PM   #68
chasedobson
chasedobson's Avatar
Denver, CO
MC Status: 1541177
a buddy of mine used the Tempest. I found it difficult to use. The OS at the time was weak. That said, it did sound good.
Dave Smith instruments kick ass.
Old 30-09-2015, 06:23 PM   #69
chasedobson
Denver, CO
MC Status: 1541177
oh, that read Template!
Thanks to chasedobson
relic (04-02-2017)
Old 10-10-2015, 08:10 AM   #70
vashima
vashima's Avatar
Pocatello, Idaho
MC Status: 13560
haha.
Old 14-10-2015, 01:35 AM   #71
timbob3k
timbob3k has a spectacular aura abouttimbob3k has a spectacular aura abouttimbob3k has a spectacular aura about
timbob3k's Avatar
MC Status: 210
Discovered templates . Making my own. In fl studio about a yr ago. Makes work flow so much faster. Also save presets uve made and like !
Sent from my SCH-I535 using Tapatalk
timbob3k is offline   Thanks Reply With Quote
Old 28-10-2015, 05:04 PM   #72
aLiner
aLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond reputeaLiner has a reputation beyond repute
aLiner's Avatar
Galway
MC Status: 2810
No. I'm against the idea of using templates (unless the purpose is just to make midi routing easier for hardware), instead of using templates I just save mixer presets for different things
aLiner is offline   Thanks Reply With Quote
Old 04-11-2015, 01:15 AM   #73
Nystagmus
Nystagmus's Avatar
MC Status: 65460
At all times on my master channel I have:
A mastering plugin for NY style compression and EQ.
A parametric EQ capable of doing Mid-Side
A Mid-Side plugin
A lookahead brick wall limiter with output set to -0.1 dBfs
Everything is disabled by default except for the limiter.
The whole chain is disabled by default so that I can overdub without latency.
Thanks to Nystagmus
vashima (12-01-2016)
Old 16-03-2016, 02:54 PM   #74
NiDBiLD
NiDBiLD has a spectacular aura aboutNiDBiLD has a spectacular aura about
MC Status: 160
I have a default template for all my projects. Got quite a few midi devices and sound generators that need routing. Would hate to redo that every time.
My default setup has 48 tracks that output from different devices. Now, I don't use all of them every time, so I start out with all the tracks hidden, and display them when I need them.
NiDBiLD is offline   Thanks Reply With Quote
Old 24-04-2016, 04:46 PM   #75
AdamThing
AdamThing will become famous soon enough
in FL Studio ill setup a few basic drum samples and then i will build onto my songs each with more samples especially different ones. most of the time i use the same synth for a bassline and each song ill tweak the bass synth a little. everything else is new. but its good to start fresh or start small.
AdamThing is offline   Thanks Reply With Quote
Old 04-02-2017, 06:34 AM   #76
Jaded
Total mad cunt
Jaded's Avatar
MC Status: 6906559
Here's my default project template for live that I use at the moment:
Basically four drum racks: Kicks, Snares (and Claps), Hats and Percs, then an empty MIDI and two empty audio tracks, and a sidechain.
Each drum rack has chain routes bussed out to their respective return tracks for individual pad routing.
I've removed all of my samples because a lot of them are from libraries. But basically, drop ALL of your kicks into kicks, snares to snares and so on. Then when you get started there's a MIDI pattern for each and you can use that to cycle through your samples.
Gain stage rack with filters, saturator and glue compressor.
Then the return tracks are A - Reverb, B - Delay and C - NI Replika sends.
Thanks to Jaded
Vault O))) (04-02-2017)
Old 12-02-2017, 05:23 PM   #77
DOLGAP
DOLGAP is just really niceDOLGAP is just really niceDOLGAP is just really niceDOLGAP is just really nice
MC Status: 360
I have template in Ableton. I loaded drum rack, couple samplers (because I mostly work with samplers) and an empty midi track plus 2 returns with delay and reverb.
DOLGAP is offline   Thanks Reply With Quote
Old 12-02-2017, 08:28 PM   #78
ms_
ms_'s Avatar
MC Status: 123160
never bothered with templates. I don't like the idea when template starts dictating my workflow which is a total mess anyway. I like to start fresh every time. I'd rather navigate and pick stuff I want to play along by myself and drag them in every time I start a new project. Doesn't take too much of time. So I'm stuck with default Live template which has 2 audio, midi and return tracks. Blank template is the best.
Old 12-02-2017, 09:52 PM   #79
Mario D
Sample Destroyer
Mario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond reputeMario D has a reputation beyond repute
Mario D's Avatar
Croatia
MC Status: 3060
I actually have Saved vst's for Bass, Kick, Snare, Vocal. In cubase you can save Insert setup. Sometimes different projects need different tweeks but overall I usually use same vst's setups for these things.
Mario D is offline   Thanks Reply With Quote
Old 12-02-2017, 11:40 PM   #80
Artificer
Ghostly
Artificer's Avatar
Southern Hell
MC Status: 37960
I have set up and used templates when I know I'm going to be doing a bunch of similar tracks (ie recording a rock band setup or whatever). Otherwise I agree with ms_ that I end up getting a bit of tunnel vision and just working around what's already there. Sometimes that's ok but I mostly like to start with a blank slate.
Project Template - DUBSTEP Red Stalker Sound Design, Mixing, & Studio Techniques 37 24-09-2014 01:23 AM
Live 9 Template for Producing sondericker The Studio 10 01-05-2014 05:45 AM
Whats your personal send FX template henryspencer The Studio 14 07-02-2013 01:49 PM
Free Ableton template djsam Sound Design, Mixing, & Studio Techniques 0 14-12-2012 11:11 AM
Template Ideas? Truesdale Workstation Center 0 13-12-2011 01:24 PM
